Instrument Panel
I was hoping for a bit of advice. I have a problem with my instrument panel on my mark 5 golf, 1.9 tdi. When i start the engine i get a bleep and "Error" message come up on the instrument panel.
The panel has been removed from before i bought the car, i have been told that its been damaged but also told that it will cost alot to go to VW and get the instrument panel changed as well as re-coded to the car.
Is it ok to buy a second hand instrument panel and get it recoded to my car by someone independent and add my current mileage back to the car?? Or would a second hand panel not be compatiable with my car?
Re: Instrument Panel
Before you do anything.. You need to get the fault codes read on the cluster.
Once you know the root casue of the issue, then assess.
Take a look in our VAG-COM section where a member maybe able to help you read the codes.
Rick
I have had the codes read a while back, it came up with something about the instrument pack. ill have to get it checked again to make sure 100% waht it is.
If you change the cluster a dealer will have to re-code the immobilisor
is it only a dealer who can recode the immobiliser? do you see any problems in getting a second hand cluster from another car tho? or any information i will need if i was to get one?
Was you not worried the the insument cluster was damaged when you bought the car? Possibly clocked?
Most VW specialists or a good locksmith would be able to recode it for you.
