Re: Backup Camera retrofit
Check the control head unit fault codes as Component protection might be in place.
No faults showing in control head - CP was removed when the unit was changed.
The only fault showing on the car is 'Camera not calibrated'
I know this is very unlikely, but it IS possible - I maybe have 2 faulty camera control units!
Mark
Post up the coding of the camera unit and the control head.
Did you set the hidden menu settings up also?
Can't post a scan up as I'm not with the car -
However, from my notes I can say this -
Can Gateway - 6C (camera) added to install list
Coding for camera control module - 1020005
Control head (07) adaptation Ch1 +38158
Comfort module (46) +2 (rear view camera installed)
Whats the hidden menu setting?
Mark
the Hidden menu
Audi MMI 2G hidden green menu description - mr-fix.info
DIAG SETTINGS
- RVC – Rear View Camera. Module 07 adaptation, channel 1, +32768.
Quote:
Originally Posted by
dan2485
Ah you mean the hidden green menu - I was thinking there was a hidden menu in VCDS!!!!!
I added 32768 earlier to module 07 adaptation ch1 which gave me 38158.
I'm back with the car tomorrow so going to uninstall everything, return all coding back to pre camera install and try again
Mark
