I know this fault code is very common
Does anyone know the resistance value of a good sensor?
Was thinking of putting a resistor between the wiring plug terminals
& clearing the fault code[emoji106]
Printable View
I do understand what you are saying, just i have gone through 3 second hand mounts & all the same & just wanted the fault off the list
why don't you buy a new one ??
how much is a new one ?? how much is an old one ??
then there is the muckabout factor in cost
Been told dealer only & very expensive as it is a hydraulic mount with sensor,
Think i may just have to live with it a while longer
if its hydraulic, maybe the seal is away and there is no oil in it ..................................
phone the parts department & ask for a price for the part, not supply and fit
isnt the normal fix to fit b5 mounts and ignore the code.
Sorted now guys!
Found a good condition one fully working for £10
Now fitted & fault code cleared with vcds & all is well!
No codes! [emoji12][emoji106]
