Audi s3 park assist
The parking sensors on my audi a3 are not working, checked all fuses and seem fine.
went into park assist via vcds and it wont let me change any coding and gives the error code rejected: error 31 request out of range.
vcds autoscan information is below:
VCDS Version: Release 12.12.3
Data version: 20140905
Thursday,25,September,2014,13:08:26:64901
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 62 72
VIN: WAUZZZ8P29A030060 Mileage: 55220km/34312miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
22-AWD -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H7FN70CS
Coding: 0103000C180F0160
Shop #: WSC 54250 000 1048576
VCID: 72EBFADA6D52A48E9D9-8027
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 16428012492500FA680B01EA921900813800
Shop #: WSC 00468 210 127455
VCID: 75E1C1C6DC3CB3B6B8B-8020
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000148 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73E5FFDE1248AD8696F-8026
2 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 54874 km
Time Indication: 0
Date: 2014.08.11
Time: 00:04:07
Freeze Frame:
Temperature: 19.0°C
Voltage: 14.20 V
RPM: 1150 /min
Load: 0.0 %
Load: 73.0 %
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 183
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Voltage: 7.20 V
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008725674
Coding: 918E8F81B0141380EE00000A0000000000084E056406040364 2000000000
Shop #: WSC 06314 123 08192
VCID: 489F78323B4E7E5E13D-801D
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
02092 - Enabling Heated Seat
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 176
Mileage: 55224 km
Time Indication: 0
Date: 2014.09.21
Time: 00:44:00
Freeze Frame:
ON
Voltage: 12.95 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52330820409962
Coding: 000003
Shop #: WSC 06314 000 00000
VCID: 41896516D8744F16D43-8014
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 51328 km
Time Indication: 0
Freeze Frame:
Temperature: 7.0°C
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49997D36E84487560C3-801C
Crash sensor for side airbag; driver side:
Serial number: 3572DRB400007A34F90Y
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000DD64D092
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400003FB0358K
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400003E408F1L
Crash sensor for front airbag; driver side:
Serial number: 35547RB40000400139B8
Crash sensor for front airbag; passenger side:
Serial number: 35647RB400004001308/
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002042
VCID: 4189651618744F16D43-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 D HW: 8P0 920 982 D
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2247H006000225
Coding: 0005408
Shop #: WSC 65536 645 577705
VCID: 3A7B12FA75A21CCE959-806F
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 55224 km
Time Indication: 0
Date: 2014.09.20
Time: 23:52:16
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 51328 km
Time Indication: 0
Date: 2014.02.05
Time: 19:41:25
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08805097E
Coding: E9A37F064002022103
VCID: 356101C65CBCF3B678B-8060
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 458171060C5C6336E8B-8010
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H7FN70CS
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H77 X---
Revision: 04S Serial number: AUZBZ7H4110141
Coding: 0209157
Shop #: WSC 00370 210 50859
VCID: 3F8D63EE6E8039E6A27-806A
1 Fault Found:
02454 - Microphone Unit (in Front Roof Module) (R164)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 175
Mileage: 55224 km
Time Indication: 0
Date: 2014.09.20
Time: 23:20:59
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 43856F1E02685D06C6F-8016
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 234 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5B22BA8502AC4EE59-807F
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
00926 - Terminal 30
011 - Open Circuit - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 44876C0207665A3EFF5-8011
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000013
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209157
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 175
Mileage: 55224 km
Time Indication: 0
Date: 2014.09.20
Time: 23:20:59
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428B6A1A1D72540ECD9-8017
Re: Audi s3 park assist
Looks like your PDC control module has cooked itself.
Thanks for that chris, any idea where it is located, and when replacing it, is it a simple swap over or does it need coding?
You have Sportback going by the rear door control modules?
If so it's in the boot, on the right hand side behind the trim panels. There is a guide here - VW AUDI Forum - VWAF
Thats for a 3 door but on the Sportback there is another screw near where the seat latches into, guide is the same apart from that.
To stop any confusion try and get a control module which matches your current - 8P0 919 475 F
Unless you have a trailer module I wouldn't bother with any coding in the module but me being me, I would check it anyway.
Your module will look like this
http://www.auto24parts.com/environme...3b39094e81.jpg
Thanks for that, just to add, when you first put the car in reverse it does beep but then after that there is nothing.
Sorry one more question
i have seen a unit with the part number
8P0919475E
my unit has the same number but an 'f' instead of 'e'
Control modules have different features and some may or may not do what you want them to do. If I were you have a look on eBay.de and try and match yours.
Update to this, im sure this unit has been changed before as the s3 has 8 sensors and the unit is for 4, anyway spoke to the dealers and they informed me that the correct module for my car ends with 'm' should be here tomorrow, will fit and update here.
thanks for the help
update:
fitted the new unit and still the same, one long beep when i first put it into reverse and then nothing.
any ideas guys as the new unit cost me £145
edit:
got it on vcds and says it needs coding, but when i try to code it, i get the same error i hade before 'code rejected: error 31 request out of range'
update, changed the car to audi a3 3 door left hand drive, and it coded straight away, but only the rear sensors are working.
