Re: Rear door will not open
Problem solved after 3 hours work.
Quote:
Originally Posted by
taxi3528
Can i ask How?
:confused:
Regards
Jim
My son did it for me, he's a panel beater. Took him ages but he got it in the end. Wouldn't tell me how .
my 2p worth
Sometimes banging on the door near the lock mechanism can help, at the same time have an assistant keep pressing the unlock button on the drivers door/keyfob.
if that fails and you are desperate enough try this:
https://www.vwaudiforum.co.uk/forum/s...d.php?t=106579
And when you get it open try this;
http://forums.vwvortex.com/showthread.php?1542461
sometimes it is a broken cable in the wiring loom to the door, most commonly in the rubber gaiter, but passat wet carpet syndrome causes problems at the A pillar on the passenger side, where the central convenience unit wiring runs, could be a corroded wire/joint there too.
taxi3528
Hes wasting his time beating panels, he should be in the
secret service :D
Regards
Jim
scotty33
my 2p worth
Maybe it takes an expert?:p
