Thread: Stereo Ignition Feed
  1. Stereo Ignition Feed
    Apr 2007
    I'm in the middle of installing an Alpine stereo in my Passat 07.
    Does anybody know an easy way to run an ignition feed to the stereo?
    I have all the correct wiring harness. The stereo has to be manually turned on and off.
    Paul
    Dec 2006
    Manchester
    There must be an existing 1 otherwise how did the stereo know when to turn off.....
    check the wiring harness for what is supposed to be the igniton live... (yellow on the standard iso connector) and then put a multimeter on it.
    must be 1 there somewhere..
    Good Luck
    Apr 2007
    The ignition is the red wire on the harness. It has a constant 12v so does the yellow.
    I don't understand how the factory stereo ran from the ignition?
    Can anybody shed any light on this.
    Dec 2006
    Manchester
    Quote Originally Posted by paulr29 View Post
    Sorry, your right, ignition live is red....
    Are you sure it's not just got a bit of a delay on it???
    Or the other possability is that it's switched from the earth..... unlikely though...
    hope you solve it soon
    Nick
  5. Smile Ignition Wiring
    Nov 2006
    Southampton
    Quote Originally Posted by bora(ing) nick View Post
    Nick
    I think you'll find that the yellow is the permanent or +12v memory feed, this one should be fed with an unswitched 12v feed that is permanently on to maintain the station presets etc.
    The red is usually the switched feed and should be routed through the ignition switch and should disappear when you pull the key from the ignition.
    Gazza57
    Dec 2006
    Wiltshire
    All the newer cars with the RCD series of units don't have an ignition feed at the radio. They are switched on and off using the CAN data bus from the vehicles control system.
    You can pick an Ignition feed up from the back of the fuse box, but it means a bit of dismantling - alternatively doesn't your cigarette lighter only come on with the accessory position on the key barrel?
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
    Feb 2007
    Quote Originally Posted by Froggy View Post
    my cigg lighter works all the time, even if im out of my car and lock it, my phone keeps charging (not that i normaly leave it in there)
  1. Where can I get a turbo oil feed?
    By SilentBob in forum Archive posts
    Last Post: 12-06-2007, 09:12 AM
  2. Stereo ignition sense problem
    By andym82 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2007, 11:50 AM
  3. A4 ignition coils
    By alansmyt in forum Audi A4 - Archive Topics
    Last Post: 17-03-2007, 10:25 AM
  4. ignition coil help...
    By SanderCH in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-02-2007, 04:36 PM
