Thread: Passenger door occasionally not opening with the exterior door handle
Results 1 to 10 of 10
  1. Passenger door occasionally not opening with the exterior door handle
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    9 Post(s)
    Doesn't seem a big problem, but does anyone know a cure?
    Audi A6 Avant 2.7 TDi Quattro Le Mans..... xenon, 19" alloys, bluetooth phone, satnav
  2. Re: Passenger door occasionally not opening with the exterior door handle
    Sep 2011
    Lurking over a keyboard ...
    I think your having the same intermittent issue as me.
    Have a view of this thread, Link:- Central locking issue
  3. Re: Passenger door occasionally not opening with the exterior door handle
    Jun 2010
    9 Post(s)
    Not quite..... Central locking works all round its just intermittently when centrally opened, the passenger door won't let the missus in
  4. Re: Passenger door occasionally not opening with the exterior door handle
    Sep 2011
    My fault in depth:-
    If I open doors via key fob or button inside of drivers door the rear passenger door won't allow a person in from outside. Then if the rear door is opened manually using inside door release it opens fine from outside handle until it is either locked via keyfob or the automatic door locking occurs when you reach x mph speed. To then again allow a person in from outside you must use the inside door release to open door as outside handle has no effect.
    To me your fault is only differing on which door its happening to.
  5. Re: Passenger door occasionally not opening with the exterior door handle
    Nov 2012
    Somerset UK
    Quote Originally Posted by poosnip View Post
    Erm...how is this a problem?
    1 2 0
  6. Re: Passenger door occasionally not opening with the exterior door handle
    Sep 2011
    I'm guessing it maybe a problem once he's out of the car!
  7. Re: Passenger door occasionally not opening with the exterior door handle
    Nov 2012
    Somerset UK
    I have the same intermittent fault with my drivers side, but have noticed more evident when damp/cold, so for example it gave me no problems over the Summer months and only started playing up last week.
    Also have noticed that it happens less after the battery is fully charged*
    As we're now midway through Nov that all drivers try (wherever possible) to trickle charge their batteries to give them a better chance over the winter months...when we'll doubtless be using electric stuff more.
    *To give you an example I was having the problem yesterday, put it on charge using my CTEK charger shortly after this post, 15hrs later the charger was still not saying it had fully conditioned/charged the battery (it can take several days to run through the whole cycle). However the drivers door is locking/unlocking every time on the 5 occasions I've tried this morn....coincidence? I think possibly when an actuator/solenoid is on 'the way out' it takes more voltage to move it.
    Jun 2010
    9 Post(s)
    Quote Originally Posted by gupsterg View Post
    My fault in depth:-
    Sorry ... Yes it is ....
    Quote Originally Posted by MarkTM View Post
    You've not met the missus !
  9. Re: Passenger door occasionally not opening with the exterior door handle
    Just wondering if this might be a useful modification for the rest of us?
  10. Re: Passenger door occasionally not opening with the exterior door handle
    Jan 2017
    Leicestershire, UK
    Quote Originally Posted by esky365 View Post
    Another one to add to the A6 Easter Eggs?
  1. Help D3 exterior door handle replacement
    By instrutec in forum A8 - S8 - V8
    Last Post: 21-05-2011, 06:28 PM
  2. front passanger door handle not opening door?
    By fabusy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-01-2011, 11:34 PM
  3. Question Drivers door handle / opening door
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2010, 08:19 PM
  4. Question Passat Exterior Door Handle
    By richiekeys123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-02-2010, 08:23 PM
  5. A6 Drivers Door Lock Sticking and door occasionally not opening
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-02-2010, 10:53 PM
