Thread: Central locking issue
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Central locking issue
    Jan 2014
    Nottingham
    Hi I have a 2006 A6 Avant that has a Central locking issue. All the doors lock except for the passenger front which can still be opened from the outside when the rest of the door are locked. I can hear the motor working inside the door when I lock and unlock the doors but I can still open the door for the outside. Any clues?
  2. Re: Central locking issue
    Sep 2011
    Lurking over a keyboard ...
    I'm having this on my rear passenger door, at times it works from outside and other times it doesn't. When I scanned with VCDS I was getting this error :-
    Code:
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0001066
       Shop #: WSC 06256 200 00000
       VCID: 69D3964F406E2869D85-803C
    1 Fault Found:
    02115 - Locking Unit for Central Locking
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 185
                        Mileage: 161495 km
                        Time Indication: 0
                        Date: 2014.11.24
                        Time: 17:35:41
    And DTC mean :-
    Code:
    VAG Error Code: 02115 Fault Location: Locking Unit for Central Locking - Implausible Signal - Intermittent Possible Cause: Wiring/Connector(s). Locking Unit for Central Locking.
    As the sunny days are coming back plan on sorting the issue and will hopefully take pics and do write up. I know there are members who've fixed this or had same issue.
  3. Re: Central locking issue
    Jul 2013
    76 Post(s)
    The door lock my friend is on its way out.
    Dan
    2009/2010 2.0 TDIe SE
    1 1 0
  4. Re: Central locking issue
    Sep 2011
    Hi ya Dan ,
    Yes indeed matey , I recall there was a thread about this topic which I think you and B5NUT were sharing your experiences.
    How much was the part BTW?
  5. Re: Central locking issue
    Jul 2013
    76 Post(s)
    A year ago i got a passenger door lock for around £114 form TPS new. This was on a friends 2006 A6 Avant.
    A rear lock should be cheaper.
    Dan
    2 1 0
  6. Re: Central locking issue
    Sep 2011
    Cheers! as you've seen this part and I haven't do you think there is something serviceable on it to make it come back to life? only ask as a) mine seems to work at times b) trying to keep costs down as recently wife had a low speed accident (she's at fault) and I need to get work done or do myself on front end.
  7. Re: Central locking issue
    Jul 2013
    76 Post(s)
    There is nothing serviceable in it, I still have it in a tool box at work and i will post up a few pictures tomorrow.
    The micro switches are potted so no real way to replace them and the lock is not easy to put back together.
    For the price of a used or new not worth the effort in trying to repair, i thought that it could be a simple switch change.
    Dan
    1 1 0
  8. Re: Central locking issue
    Jan 2011
    Stafford, UK
    This chap repaired his lock, may be of interest to others - A6 (A3, A8) doors not unlocking. - AudiWorld Forums
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
    2 1 0
  9. Re: Central locking issue
    Sep 2011
    Quote Originally Posted by royclark View Post
    Roy! Cheers for that mate! as mine is intermittent I think I will have a meddle with it first! if I didn't I don't think I'd qualify as a "meddling owner" ...
  10. Re: Central locking issue
    Nov 2012
    Somerset UK
    I have a similar problem with my drivers front.
    I've noticed in temps above 10 degrees it doesn't happen, for now am happy to open the rear drivers side and open rather than spend £££'s fixing....hopefully for Summer it will be trouble free
  1. Central Locking Issue
    By begbie553 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-08-2012, 08:08 AM
  2. Central locking issue
    By holly.arnott in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-02-2009, 06:48 PM
  3. Another issue with central locking.
    By timjinks in forum Golf MK5 - 2004 - 2009
    Last Post: 11-09-2008, 07:02 PM
  4. Question Central Locking Issue
    By Pioden in forum Octavia
    Last Post: 16-06-2008, 01:59 PM
  5. Central Locking Issue
    By srobins in forum Passat - Archive Topics
    Last Post: 29-01-2007, 11:06 AM
