Thread: 130hp TDI - Common issues?
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. 130hp TDI - Common issues?
    Kent
    I've pretty much got my heart set on a 130hp TDI Saloon Passat, so have been looking at reviews for them, and the issues that have commonly appeared are:
    Split turbo hose's (Some people have had this problem more than once), Water Pump, Air Flow Meter and EGR Valve.
    I also read about recalled Gearbox's(?), Footrest's breaking (What on earth is a footrest?!) and also that they eat front tyres..
    Just wanted to ask exactly how common are these problems?
    And also how to check for any of these issues when actually looking at the car..
    Thanks,
    Dan.
  2. Smile Re: 130hp TDI - Common issues?
    Jun 2008
    I've never heard anything about recalled gearboxes, they are generally pretty solid boxes. Mine is a 6 speed with 90k on it, still quiet box and good gear change.
    Re:
    Split turbo hose's (Some people have had this problem more than once), Water Pump, Air Flow Meter and EGR Valve. - I don't think the passat is any worse than any other car for this. It would still be wise to check the hoses are in decent condition before buying.
    Re: eating front tyres, it is quite a heavy car so I can understand the point here, but I don't think it's any worse on tyres than any other car I've had. Obviously if you hammer it, the tyres will wear faster than normal.
    As for the footrest, mine is solid...
    They are great cars, and they Tdi is a great engine, you can't go wrong. Just look at the number of them used as taxis. A good motor
  3. Re: 130hp TDI - Common issues?
    I put 24k on my tyres and they are still ok , had the car 2 years and not spent a penny on it yet , other than for oils filters and brakes.
    MY only gripe is front wheel drive in the wet added to 130 bhp of grunt which i just remapped to 178 bhp and it sucks big style.
  4. Re: 130hp TDI - Common issues?
    Kent
    Quote Originally Posted by garnier View Post
    Re:
    Are they easily accessible to check?
    Quote Originally Posted by passat 130 tdi View Post
    How much torque you running mate?
    Thank you both for the replies!
  5. Re: 130hp TDI - Common issues?
    around 300 jimmy neutrons
  6. Re: 130hp TDI - Common issues?
    Kent
    300nm with a 178hp engine..?!
  7. Re: 130hp TDI - Common issues?
    aye !! standard is 220 .
  8. Re: 130hp TDI - Common issues?
    Kent
    I thought the 130hp engines had 320nm as standard?
  9. Re: 130hp TDI - Common issues?
    Mike McKinstry Guest
    Also common faults-
    plenum chamber drain blockages causing flooding of electrics.(CMM)
    leaks into CMM through pollen filter.
    leaks via rear door skins into rear footwells.
    freezing rear washer hoses pushing off washer,soaking boot m/switch and setting off alarm.
    VNT carboning up causing limp home mode.
    vacuum leaks.
    electric fans breaking.
    headlight adjusters breaking.
    faulty temp senders
    Wifes 1st passat and has experienced most of above bar leaks from plenum to interior because this is checked regularly.
    Regards,
    Mike
  10. Re: 130hp TDI - Common issues?
    Kent
    Quote Originally Posted by Mike McKinstry View Post
    Also common faults-
    vacuum leaks.
    faulty temp senders
    Regards,
    Mike
    What precautions should I consider for each of these points?
  1. GT TDI 140...issues?
    By leegary in forum Golf MK5 - 2004 - 2009
    Last Post: 21-04-2008, 04:54 PM
  2. Replies: 0
    Last Post: 21-04-2007, 05:47 PM
  3. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
  4. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
