Thread: Parking sensor retrofit - Passat estate
Results 1 to 10 of 15
  1. Lightbulb Parking sensor retrofit - Passat estate
    Mar 2007
    Oxfordshire
    This isn't as bad as it sounds - honest! I bought a very cheap 4 sensor kit off eBay (very sucessfully fitted to my A3 in the past) however I soon realised there was a problem with these sensors and the estate... My intention had been to carefully measure and cut the sensors into the lower rear bumper and then plug the rest in (easy). However the lower rear bumper curves much more than other VW's of this era meaning the sensors would point down at 45 degrees - no good at all. I certainly wasn't going to put them in the upper part of the bumper - what a bodge! I phoned VW today and ordered the lower rear bumper with sensors built in - increadibly it was only £39 - bargain! So I'm hoping to join the VW sensors into the cheapy eBay kit - cutting and soldering wires if necessary.
    has anyone done this kind of thing before on the Passat estate - any tips?
    Jun 2006
    UK, Mids
    It doesn't come with the sensors built in, I have just fitted one last summer, £39 gets you four strange holes. The sensors are £75 each I kid you not!
    I fitted a £25 BREES kit of ebay. I'll post a pic tomorrow. I had to cut away some plastic at the back and apply silicone sealer to hold them in.
    There is a connector on the rear light cluster (either side) with goes 12v when R is selected, you can make the power cables with mini-lucars crimped on and it plugs straight in.
    Mar 2007
    Oxfordshire
    I thought £39 was a bit too good to be true! I would be very interested to see how you did it, I really don't want to make a bodge - I am happy to make some careful modifications if need be. As far as I can tell all of the eBay kits have the same sensors - about 20mm diameter with a lip - they don't quite look like the VW ones - I guess the lip needs trimming off etc. Alternatively would cutting the new bumper to have bigger holes be a very bad idea? Thanks for your reply
    Jun 2006
    UK, Mids
    Sorry the pics aren't the best, I can't really get my big SLR up high enough to take one from behind...
    You will be fine, the valance has tubes in which the factory sensors are slid into, you just need to mount yours in these and put some sealant in from behind so that filth and water doesn't build-up inside. Take the sensors from the sensor side while the sealer cures. make sure they are all aligned the same within the holes. For the wires, you can make poke holes with a hot nail in the moulding reinforcements and put small cable ties through.
    Good luck!
    Mar 2007
    Oxfordshire
    They look great - thanks for the photo - I will give it a go this w/e. I can't believe VW charge £75 for each sensor - that's outrageous! Will post photos pending fitment, thanks
    Apr 2007
    hi all new to the forum so go easy on me lol are these parking sensors worth the money ? thinking of getting a set ??
    Jun 2006
    UK, Mids
    Yes, they're great fun!
    I just use the chimes, I hid the display in the CD changer rack in the boot behind the trim.
    If I had time, I would take apart my display as the backlight turns green/amber/red, and I would solder telephone cable on and run it to the boot light and install 3 bright LEDS in that as a warning.
  8. Thumbs up Parking sensor retrofit - they're grrreat!
    Mar 2007
    Oxfordshire
    I fitted parking sensors last week and they are fantastic! My Passat is an estate so I had to buy the modified lower rear bumper (£46), so they point in the right direction.
    Removing the old bumper and fitting the new one took about an hour - don't force it as there are hidden fittings in the wheel arch (see Haynes manual). I bought a set 4 sensors with buzzer only off eBay for £12.50 and stuck them in the holes with super glue and silicone - they look great. The elctronics is straight forwards if you have a multimeter.
    Very much recommeneded upgrade for £70ish!
    Jun 2006
    UK, Mids
    Nice colour of Passat Randall, I wished mine was that nice blue!
  10. Re: Parking sensor retrofit - Passat estate
    Dec 2007
    Nr Newport S Wales
    7 Post(s)
    Hi All, I too went the route of replacing the spoiler for one with the sensor mounts and I then bought a Ciba sensor kit off EBAY. Total cost around £80. I mounted the sensors parallel to the mount tubes but find that with the Ciba sensors it often picks up the road. I'm guessing that the beam angle must be quite wide on the Ciba sensors as any slight incline behind or weight in the boot and they sense. Can you advise what sensors you used as if I can find one with a narrower beam angle it may solve my problem. I don't really want to angle them upward any further as they will not sit flush with the spoiler then and could look bad.
    Do any of you guys get false alarms?
    Thanks for any advice you can offer.
    B5.5 Estate TDI 130 4Motion
  1. Passat B6 Electronic Parking Brake
    By Iainrugby in forum Passat - Archive Topics
    Last Post: 09-11-2007, 10:27 AM
  2. Passat Aero Wipers - retrofit
    By randall977 in forum Passat - Archive Topics
    Last Post: 10-06-2007, 09:37 AM
  3. passat parking sensors
    By schoey1 in forum Passat - Archive Topics
    Last Post: 31-05-2007, 01:18 PM
  4. Retro-fitting parking sensors : 2001 Estate
    By randall977 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-04-2007, 10:02 AM
  5. FS: Passat B5.5 parking sensor kit (estate)
    By Carps in forum Passat - Archive Topics
    Last Post: 09-02-2007, 06:27 PM
