Thread: caddy diesel pump
Results 1 to 10 of 13
  1. caddy diesel pump
    hi to everyone, need help is possable ,i have got vw caddy van 1.9d 1997 but need to change the diesel pump is it possable to use a secound hand one or is it coded to the ecu if so is there a way round the codeing many thanks darren.
  2. Re: caddy diesel pump
    135 Post(s)
    2040 Post(s)
    Which engine code, 1Y?
  3. Re: caddy diesel pump
    hi. yes the engine code is 1y
  4. Re: caddy diesel pump
    135 Post(s)
    2040 Post(s)
    Yes, the pump is coded.
  5. Re: caddy diesel pump
    hi, is there a way round the pump being coded .
  6. Re: caddy diesel pump
    135 Post(s)
    2040 Post(s)
    Not that I know of, it's no big deal if you have VAG-COM.
  7. Re: caddy diesel pump
    hi. could it be done if i got the ecu and the pump ?
  8. Re: caddy diesel pump
    Mar 2007
    coventry
    keys ecu pump
    no matter how you try you always come back to what you first started
  9. Re: caddy diesel pump
    135 Post(s)
    2040 Post(s)
    The ECU is in the pump, you would need the donor vehicles immobiliser unit and the chip out of the ignition key.
  10. Re: caddy diesel pump
    hi , thanks for your help ,sorted it today,i smashed the immoberlizer bit of the back of the pump and then ran a wire to the solinoid works a treat.
  1. Diesel Pump Question
    By ghee60 in forum 80 - 90
    Last Post: 04-04-2009, 10:32 PM
  2. diesel pump remove and refitting
    By badersbus in forum The Commercial Range
    Last Post: 31-12-2007, 02:21 PM
  3. vw caddy diesel non starter
    By squawwoods in forum The Commercial Range
    Last Post: 13-11-2007, 11:07 PM
  4. Diesel Injection Pump Leak
    By AutoTDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-06-2007, 04:04 PM
  5. A6 2.5 TDI diesel fuel pump problems
    By acetaylor in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 08-05-2007, 01:42 PM
