Thread: Lane Assist - Permanently reactivates
Results 1 to 10 of 17
  1. Lane Assist - Permanently reactivates
    Aug 2020
    Birmingham
    9 Post(s)
    Does anyone know if VW have any plans at to make it so that I can disable Lane assist permanently.
    1. It's really quite annoying to be forced to disable it every time I start the engine, especially on a journey with multiple stops.
    2. It makes the steering feel heavy and less responsive.
    3. It tries to steer you back into lane when overtaking parked vehicles, its not much of a fight but its annoying as hell.
    I get that it's a 'safety feature'. But It doesn't really work that well in the UK with its abundance of smaller roads with parked cars on it.
    Ideally they should let me deactivate it permanently or maybe have it so that it engages at speeds of 40mph+?
  2. Re: Lane Assist - Permanently reactivates
    Aug 2016
    South Lakes, UK
    29 Post(s)
    Quote Originally Posted by djangophi View Post
    I thought it only engaged over 30. I've got used to it now and don't find it much of an issue.
    You'll be able to turn it off permanently with something like vcds but as it's listed as a safety feature I doubt they'll let it be done in the car.
    Sent from my ELE-L29 using Tapatalk
  3. Re: Lane Assist - Permanently reactivates
    Aug 2020
    Birmingham
    9 Post(s)
    Quote Originally Posted by jmagee View Post
    Thanks. I'm not sure I can get used to it, I find the steering is so much more responsive without it.
    I'm also of the viewpoint that I should have full control over the thing I'm paying thousands for
    So , How do I go about pursuing this vcds avenue?
  4. Re: Lane Assist - Permanently reactivates
    Aug 2016
    South Lakes, UK
    29 Post(s)
    There's a VCDS users group on Facebook. Guess find someone local that can have a look? Maybe VW retrofit or someone like that would have a look too.
    Problem is being a new car people might be worried about messing about with the coding.
  5. Re: Lane Assist - Permanently reactivates
    Apr 2009
    Surrey
    183 Post(s)
    Permanently disabling "safety" features is likely to be a total no no. The car is type approved with them active and also for Euro NCAP rating so disabling them would make the car "not as manufactured" and at the very least you would have to advise your insurer so as not to invalidate your policy. As of 2022 Lane Assist and many other features will become mandatory in the EU (and the UK even though we will have left) Press corner | European Commission Lane Assist is only active above 50km (38mph).
  6. Re: Lane Assist - Permanently reactivates
    North Yorkshire
    11 Post(s)
    My son just got the new Audi A1 with lane assist, and can turn it off completely. It doesn't come back on unless he turns it on.
    It's easy to turn off when you first start the car, just two buttons on the steering wheel.
  7. Re: Lane Assist - Permanently reactivates
    Aug 2020
    Birmingham
    9 Post(s)
    Quote Originally Posted by Pinocchio View Post
    Unfortunately it's not so straight forward on the Golf 8, its quite distracting if you forget to do it immediately and you're driving as its 1 button press followed by 2 on screen presses.
  8. Re: Lane Assist - Permanently reactivates
    North Yorkshire
    11 Post(s)
    Two buttons on steering wheel to turn off lane assist whether driving or stationary.
    1.Press button 1 and lane assist shows in instrument panel.
    2. Press button 2 to remove tick.
    3. Press button 1 again to take lane assist off screen.
    I have done this from day one with my mk8 and never had to use touch screen to turn it on or off. Now i don't need to look at any screen to turn it off.
  9. Re: Lane Assist - Permanently reactivates
    Aug 2020
    Birmingham
    9 Post(s)
    Thanks for the info.. I tried that as it sounds very handy,
    However when I press button 1 all that happens is it message pops up saying travel assist activate/deactivated. It doesn't show anything with ticks.
  10. Re: Lane Assist - Permanently reactivates
    Jan 2013
    Northern Ireland
    32 Post(s)
    I think we're talking about two different systems here - Lane Assist and Travel Assist.
    Lane Assist (or, as the manual describes it, the Lane Keeping System) is a passive system which nudges the steering if the driver wanders out of lane. It operates above 60km/h (around 37mph) and is always switched on by default at start-up. When it is operating, the lane assist symbol appears on the virtual instrument display coloured green. If intervention is required, this symbol turns amber. In addition to the steering nudge, the system can oprionally be set to vibrate the steering wheel. This option is in the assist systems menu and can be found by touching an edge line when the picture of the vehicle is displayed on the infortainment screen.
    Some cars are optionally fitted with Travel Assist. You will know if this is the case because the bottom right symbol on the left hand steering wheel control looks like this:
    Travel assist is an active system. When you press the button the car is automatically steered within the lane markings. In addition, the adaptive cruise control is set. When travel assist is engaged, the symbol on the instrument display is a combination of the Lane Assist and ACC symbols. Travel Assist seems to operate at any speed (once the button is pressed). I find it works well, especially on motorways or well marked rural roads.
    If Travel Assist is not engaged, then the Lane Assist system operates as described above.
    As far as I can see, the method helpfully described by @Pinocchio to switch off lane assist does not work on cars equipped with Travel Assist because pressing the bottom right button simply engages Travel Assist.
  1. Lane Assist
    By Michaels8666 in forum Q7 - 4M Forum - 2016 -
    Last Post: 14-02-2020, 12:40 AM
  2. Lane assist
    By Linstock in forum Audi A6 - C8 Forum - 2019 -
    Last Post: 20-01-2020, 12:27 PM
  3. Lane Assist and Traffic Jam Assist on a 2018 Passat
    By Fschaeffer in forum Passat - B8 Forum - 2015 -
    Last Post: 30-10-2017, 08:57 PM
  4. Lane Assist and Traffic Jam Assist on ACC equiped Passat
    By Fschaeffer in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 29-10-2017, 07:15 PM
  5. lane Assist (crosspost)
    By lozzer in forum Golf MK7 - 2013 - 2019
    Last Post: 25-03-2013, 09:23 PM
