Thread: Fitting new gear knob and gaitor
Results 1 to 8 of 8
  1. Fitting new gear knob and gaitor
    Sep 2007
    Maryport, Cumbria
    Currently I have a chrome flashing chav gear knob in my car - Courtesy of the previous owner, but now I have found a standard gear knob and gaitor for £18 - not bad IMO.
    Just wondering would this be easy to fit? Also, would the gear knob and gaitor come seperate so that they wouldn't be 'stitched' together?
    Any help is appreciated
  2. Re: Fitting new gear knob and gaitor
    Mar 2007
    coventry
    can we have a pic of ??
    no matter how you try you always come back to what you first started
  3. Re: Fitting new gear knob and gaitor
    Sep 2007
    Maryport, Cumbria
    Quote Originally Posted by golf tdi 02 View Post
    You can, but as I've said works computer won't let me post pics, grrrr.
    Basically, the ger knob is stuck on the stick ha! Can easily be pulled off, however, how would I fit the standard knob? Does it come with simple minded instructions for simple people? Also does the gaitor just pull of too?
  4. Re: Fitting new gear knob and gaitor
    Dec 2006
    Manchester
    Quote Originally Posted by emma_88 View Post
    Well, here are some pics of how the standard gear nob and gaitor attached.....
    The gaitor just lifts up from the back, (big lip on the front edge) and then just slides over the gear nob in 1 piece.
    Theres a fitixg on the shaft that looks like it holds the gear nob in place? You may need to put a small jubilee clip around yours to secure it. (or just leave it, and it'll probably be the same as you have now)
    Looks simple enough?
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  5. Re: Fitting new gear knob and gaitor
    Sep 2007
    Maryport, Cumbria
    That's greats. THanks very much!
    Just one question, did you not need to take the gear knob off at all to remove the gaitor? I thought the gear knob and gaitor were attached?
    You make it look oh so simple
  6. Re: Fitting new gear knob and gaitor
    Dec 2006
    Manchester
    Have a look at the first photo..... the gaitor is still attached, just inside out
    Nick
    1.9 tdi PD 100 Bora
  7. Re: Fitting new gear knob and gaitor
    Sep 2007
    Maryport, Cumbria
    Quote Originally Posted by bora(ing) nick View Post
    Nick
    Ahhh, I see.
    Muchos gracias
  8. Re: Fitting new gear knob and gaitor
    Sep 2010
    London
    I have a golf 2001, but I am not sure if the hole inside the knob is 12mm or 22mm.
    I was wondered if anyone knows that.??
    thanx
  1. Gear lever gaitor
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-03-2011, 11:28 PM
  2. gear knob removal
    By littlejim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-10-2007, 10:51 PM
  3. B5 replacing the gear stick gaitor?
    By jedi172 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 04:22 PM
  4. Gear Knob insert?
    By valley rower in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-07-2007, 10:26 AM
  5. Gear knob removal
    By CABBIE in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-05-2007, 01:57 PM
