Thread: Auto box reverse problem - help!
Results 1 to 10 of 12
  1. Auto box reverse problem - help!
    Hi all, I have a problem and need help -
    I own a W reg 1.9 TDi with the auto (tiptronic) box and I seem to loose reverse as soon as I touch the accelerater! Sometimes it catches and reverses as normal but most times you can hear and feel reverse gear engage and then it dissapears as soon as the revs increase - as if the clouch were being pressed on a manual.
    Now, i've have the valve chest looked at and been told there's no faults - and the auto transmission guy who looked at this said he's never known anything like this before!!! does this problem sound familiar to anyone out there?
    This car has already had two gearbox recon's in it's life and it's just 7 years old!
    i'd be greatful if anyone could shed some light on this or point me in the direction of a transmission firm that can pin point the problem and sort it out.
    Ironic really! i've spent most of my life going backwards - now my car refuses to.
    Dan
  2. Re: Auto box reverse problem - help!
    Anyone ? or is just me!!!!!
  3. Re: Auto box reverse problem - help!
    abertridwr south wales
    Hi dan ive got the same problem as you if you givemy 2001 tdi any gas while reversing it just revs and wont go anywhere vw say the box is fine so we are both in the same boat!
  4. Re: Auto box reverse problem - help!
    Thanks for letting me know - i've no idea where to go with this problem, no body seems to know what it could be - and i don't really want to pay for another gearbox recon to then be told it's an electrical fault!!!!
    I thought these cars were pretty bullet proof - obviously not!
    If i find a cure - i'll post back on here, and if you find a cure i'd be greatful if you could let me know.
    Cheers,
    Dan
  5. Re: Auto box reverse problem - help!
    134 Post(s)
    2018 Post(s)
    bullet proof
    On a more serious note, I have never come across that problem.
  6. Re: Auto box reverse problem - help!
    Thanks Crasher - what valuable input!!!!
  7. Re: Auto box reverse problem - help!
    134 Post(s)
    2018 Post(s)
    Sorry, normally I am more help than that!
  8. Re: Auto box reverse problem - help!
    I have just bought a A4 (30v V6) with a tiptronic gearbox which has the exactly the fault you described.
    I have spoken to a autobox specialist yesterday who is going to diagnose the fault when I get chance to let him have the car. This involves checking the fault codes and oil pressures. He says this gearbox doesn't rely heavily on oil as other auto gearboxes and talks about problems from a sensor failure to reverse clutch failure.
    I will keep you informed after I have been there, hopefully next week.
    I'll keep checking back to see if anyone else has posted anything interesting here.
  9. Re: Auto box reverse problem - help!
    Hi Andy - that would be a great help - thanks, Dan
  10. Re: Auto box reverse problem - help!
    GMF Guest
    try asking on this forum lads its a yanky forum and well informed
    http://www.importperformancetrans.com/forums/
    Glynn
  1. Reverse gear problem
    By kenharkin in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-11-2007, 05:51 PM
  2. auto box problem
    By kharva007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2007, 08:53 PM
  3. VW Sharan auto 5 speed tip-tronic no reverse
    By mushy in forum Archive posts
    Last Post: 06-06-2007, 08:37 PM
  4. A4 Estate (1997) reverse light problem
    By bigcrags in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-04-2007, 10:52 AM
  5. V6 TDI Auto Problem
    By Kevin in forum Passat - Archive Topics
    Last Post: 05-09-2006, 05:05 PM
