Thread: 1.9 Tdi Water Ingress
Results 1 to 8 of 8
  1. 1.9 Tdi Water Ingress
    ireland
    HI EVERYONE, READ ALL THE THREADS ON WATER GETTING IN ON FOOTWELL,I DECIDED TO CHECK MY OWN .SURE ENOUGH DRAINS UNDER BATTERY WERE STUFFED WITH GUNK.I SHOULD HAVE SAID AT START I DONT HAVE WATER PROBLEMS BUT SHOULD I REMOVE POLLEN FILTER CASING AND RESEAL IT OR IS IT A CASE OF IF ITS NOT BROKE DONT FIX IT? THANKS PAUL.
    May 2007
    knee deep in clunge
    14 Post(s)
    Hello Paul,yes i would replace the seal also use some dum dum paste as extra seal so it is water tight.Put a run of dum dum in the seals fitting place first then put the new seal on top and reasssemble.
    ireland
    Thanks For The Advice,will Do That Today If It Stops Raining.3 Nuts Holding Casing....right?
    May 2007
    knee deep in clunge
    14 Post(s)
    yes 10mm i think
  5. Help ! ! !
    May 2006
    Wife reported funny smell in 130PD estate, checked the carpets - whoopidoo - soaking . I've pulled the battery out cleaned the blocked drain (both sides..) pulled wiper arms / front cover to remove pollen filter, D shaped gasket split in 3 places and perished. Pulled carpets - tons of water.
    The road outside our house is heavily cambered so all the water from the roof /windscreen ends up in the leaky pollen flilter area - cosmic.....
    Decided to remove passenger seat - easy makes the clean up a lot easier as water was in the rear well too. emptied over 2 gallons - yes 2 gallons of water out luckily not entered CCM module. pulled carpet over to drivers side to let it drain ( Manmade fibres do not hold water well).
    All I need is new D joint - anyone any idea of the VW part number?
    Loads more fun than watching French GP....
    Apr 2005
    County Durham
    well i was about to post asking about this. We also have had 2 " yes "2 of water in the front of ours today, This is obviously why, will remove the scuttle tray tommorrow as i need to insatll cruise any ways and sort it out
    VW PASSAT PD 130
    Apr 2005
    County Durham
    Corrupt and Damaged Seal had caused this for me...... Replaced today and it seems to have resolved
    VW PASSAT PD 130
    Bradford/West Yorks
    This thread has been a good insight... ive not got any issues with water i dont think but will check the seals etc accordingly.
    Its due to go in for a major service so if i ask them to do it then i wont have to i presume?
  1. Water ingress probs
    By SosolidVw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-11-2007, 07:04 PM
  2. Water ingress/CCM failure
    By quantum_man in forum Passat - Archive Topics
    Last Post: 14-03-2007, 12:01 PM
  3. Water ingress.
    By Whocantellyer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-03-2007, 03:57 PM
  4. Water Ingress?
    By kriskros in forum Passat - Archive Topics
    Last Post: 26-12-2006, 08:09 PM
  5. Water ingress probs
    By SosolidVw in forum Passat - Archive Topics
    Last Post: 19-09-2006, 01:18 PM
