Thread: Imminent DPF failure or something else.
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 74
  1. Re: Imminent DPF failure or something else.
    #41
    Flitwick
    Well my cat has been so far, the one in the picture... £471 for an enema... and you thought garages knew how to charge!
    ouch I’m sure it was worth it
    Steve
    2014 Passat Estate
    Executive Style
    2.0 TDI Bluemotion
    Tungsten Silver
  2. Re: Imminent DPF failure or something else.
    #42
    1840 Post(s)
    He is.
    0 2 0
  3. Re: Imminent DPF failure or something else.
    #43
    Dec 2020
    was 1 of Bonds enemies involved?
  4. Re: Imminent DPF failure or something else.
    #44
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    He is.
    Is he a Maine Coon? Or just Mr Fluffy.
  5. Re: Imminent DPF failure or something else.
    #45
    1840 Post(s)
    Norwegian Forest cat, just over 10kg, called Sprocket
  6. Re: Imminent DPF failure or something else.
    #46
    Jan 2013
    109 Post(s)
    Wow! Lovely boy!
  7. Re: Imminent DPF failure or something else.
    #47
    Sep 2019
    Coventry uk
    8 Post(s)
    Luckily for me my ‘CAT’ was not so expensive
    Problem with wiring to the DPF pressure sensor. Resolved and a full DPF static regen and forced regen run. Seems ok now but recommend a full service as the oil is really thin because of the amount of regens. After discussing with the technician we have come to the conclusion that temperature sensor 1 is acting a bit odd and so need to change that. Think it’s the one on the Turbo. Any idea on the part number?
  8. Re: Imminent DPF failure or something else.
    #48
    1840 Post(s)
    I had a 2016 SQ5 in today, the DPF is loaded at 21% and needs a forced regeneration. I tried this with VCDS and it would not respond so I resorted to ODIS at 10 Euro an hour, this went straight in and then asked me if I had fitted blocking tool T14 something or other into each rear silencer as the tailpipe gas temperatures of circa 500C will damage the rear silencer speakers, made by Bose. These are roughly £800 each and the tool £80 each so I would need two... I asked Audi and they said the tool does not guarantee no failure of the speakers and they will only fit a new DPF at £2200. The customer asked about cleaning and I said yes, that is what we always do BUT after cleaning we have to do a forced regeneration so 500C again... this is getting stupid! I really have had enough of this ****.
  9. Re: Imminent DPF failure or something else.
    #49
    Sep 2019
    Coventry uk
    8 Post(s)
    Hi Crasher, I feel ur pain. How many people would have bought a car with these problems stored for the future. I almost feel like I should have carried on getting the cheaper car and not worrying about all these expensive fixes. Off to sort a new sensor now at circa £150.00
    Had a Ford Mondeo 2.2TDI before and apart from normal wear and tear cost less to buy and run than the Audi. Same Euro catergory and more miles!
  10. Re: Imminent DPF failure or something else.
    #50
    Sep 2019
    Coventry uk
    8 Post(s)
    Is this the part number of the sensor for the turbo?
    03l 906 088 be
  1. New A7 imminent order.
    By roydoshi in forum A7 - S7
    Last Post: 13-06-2017, 03:44 PM
  2. A6 Price Rise Imminent
    By johnsimcox in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-03-2015, 11:51 AM
  3. Shark Remap imminent :)
    By furfurfur in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-06-2013, 04:48 PM
  4. Please Help Power steering pump imminent failure?
    By Saturn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-09-2012, 12:12 AM
  5. Golf hit with serious mechanical failure - 1.6TDI Turbo Failure
    By dactel in forum Golf MK6 - 2009 - 2013
    Last Post: 03-02-2010, 07:57 AM
dpf
