Thread: MK4 Golf TDI starts from cold with temp sender disconnected
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 73
  1. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #21
    Sep 2007
    Bath, England
    Thanks for the help, has any one replaced this before, or know how to?
    Is in the green part you are refering to?
    Alex
  2. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #22
    2018 Post(s)
    That is the early plug, pre mid 99 and so the connectors are easier to change. I can't tell if that is rust, copper grease (which it looks suspiciously like on the plug) or gold plating. If I change those terminals, I always use gold plated versions. If you try and buy them from VW you get a terminal fitted to a piece of yellow wire which is supposed to be soldered in as they don't trust spanner monkeys to do the job properly, with good reason. I buy the terminals from Würth (they are made by AMP) and I crimp them on. Those earlier ones are much easier to do than the later micro timer connections.
  3. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #23
    Sep 2007
    Bath, England
    Thanks for all the replies, much appreciated.
    Would you reccommend that I get the green part and see how that goes, what is that part called? Also what is the correct name for the plug itself?
    Is is a case of removing the current part and simply plugging a new one in? Would I need to disconnect the battery and drain some coolant from the engine?
    Regards
    Alex
  4. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #24
    2018 Post(s)
    PM me your reg or chassis number and I will post the part numbers.
  5. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #25
    2018 Post(s)
    That is the wrong sensor and plug for a 99 Bora, the sensor you have there is not the 059 919 501 A it should have and neither is it the earlier 059 919 501. Can you take it out and have a look to see what the VW part number is? Also, peel back that insulation on the wiring; I have a feeling there will be some soldering not far back, that isn't the original covering.
  6. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #26
    Sep 2007
    Bath, England
    Didn't have any luck removing that green part, does it just pull out, I gave it some stick. Should I expect coolant to pour out, its Horizontally orientated. Will try again in morn.
  7. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #27
    2018 Post(s)
    You did slide out the clip? It then just pulls out and yes some coolant will be lost.
  8. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #28
    Sep 2007
    Bath, England
    Will have another crack when im off again. Car is booked in for Cam Belt, Break discs, pads, water pump and service next week. Bank balance won't be happy, but will have peace of mind.
    Alex
  9. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #29
    Sep 2007
    Bath, England
    Right, finally had a few minutes to have a go at this, the numbers on the green plug are - 059 919 501 (07-03) EH2 12V-140ma
    As for the wiring, it goes back inside a plastic housing. Do I need to check this for soldering?
    Alex
  10. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    #30
    Dec 2007
    inverness/glasgow scotland
    i have this exact problem on my golf 115 2000, can someone tell me where my sensor is so i can check it please......
    thanks
    Golf GT TDi
    115 bHP
    6 Speed
    Audi 18 inch alloys
  1. Cold Morning Starts
    By Stevebt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2007, 11:43 PM
  2. Temp sender.
    By Woz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2007, 02:40 PM
  3. 2002 golf gti turbo cold poor starts!
    By givememorepower in forum Archive posts
    Last Post: 09-07-2007, 01:58 PM
  4. water temp sender
    By taff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-12-2006, 09:34 AM
  5. 110 BHP TEMP SENDER
    By belle2uk in forum Passat - Archive Topics
    Last Post: 23-08-2006, 12:26 AM
