Thread: Hot starting my 1.9 TDI Sharan
Results 1 to 10 of 11
  1. Hot starting my 1.9 TDI Sharan
    Dec 2007
    Redruth, Cornwall
    May have posted in the wrong place so have put a link here just in case.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=21491
    Basically am having trouble starting the engine when hot. Cold is fine, no probs. When hot, turns for ages before firing.
    Am looking to hook up to a Vag Com unit to see whats going on...any advice?
  2. Re: Hot starting my 1.9 TDI Sharan
    Hi, sounds like a possible fault with the temp sensor
  3. Re: Hot starting my 1.9 TDI Sharan
    Dec 2007
    Redruth, Cornwall
    Quote Originally Posted by kenney View Post
    Would something like this show up on VAG COM?
  4. Re: Hot starting my 1.9 TDI Sharan
    Hi again usualy but not always,it might sound stupid,but rather than use a lot of time trying to find the fault,especially if it is not logged in the ECU,with the symtoms you have it is quicker to just replace the sensor.99 times out of 100 it is the sensor and if it should be 1 in a 100 then that is when the real problem starts.
  5. Re: Hot starting my 1.9 TDI Sharan
    Dec 2007
    Redruth, Cornwall
    Thanks Kenney, will add a temp sensor to my brake light switch order.
  6. Re: Hot starting my 1.9 TDI Sharan
    Bristol
    Engine code and year of your sharan pls ?
    MK5 Golf TDI 2.0ltr GT Sport in Black
  7. Re: Hot starting my 1.9 TDI Sharan
    Dec 2007
    Redruth, Cornwall
    Quote Originally Posted by cbrpaul View Post
    Its a 99 on a T plate, where would I find the engine code? The car is new to us so am a bit of a n00b!
  8. Re: Hot starting my 1.9 TDI Sharan
    Bristol
    probably a AFN same as mine
    I have a hot start problem , well did ,
    Basically the ECU will not inject fuel into the engine until 250rpm are reached upon cranking,,, this call from the ecu is only when the engine is warmed up !!!
    One way to check is to remove the coolent temp sensor connector when hot , as the ECU will default to a cold start map !!
    If it starts easily then its this ECU hot start call,
    Over the years the starter is not as good , therefore struggles to meet the 250rpm , you can try a new starter , but most are re-con units though , so you could buy a new 1 and it still be present !!
    The only other way to cure it is to use vagcom !!
    Have you got this or is someone close to you who has it ?
  9. Re: Hot starting my 1.9 TDI Sharan
    Dec 2007
    Redruth, Cornwall
    cbrpaul, been away for a couple of days...got home to find V5 reg document and yes mine is the AFN engine....hope thats a good one!
    Have ordered my dumb lead and have the Vag Com software all ready to go. Funnily enough the wife has said the car has been running fine with no startring issues.....
  10. Re: Hot starting my 1.9 TDI Sharan
    Feb 2007
    Hi There Any Body With A Vagcom In Birmingham? Many Thanks.
    Take Care.
  1. Hot starting, 1.9 TDI Sharan.
    By 1.9 TDI Sharan in forum Archive posts
    Last Post: 10-12-2007, 12:31 AM
  2. Starting Sharan when engine is hot
    By jomaz in forum Touran - Sharan - Caravelle
    Last Post: 22-07-2007, 05:30 PM
  3. Sharan TDI Starting problems
    By Lawrence in forum Touran - Sharan - Caravelle
    Last Post: 18-07-2007, 10:39 PM
  4. Sharan starting Problems
    By skeendoo in forum Archive posts
    Last Post: 29-03-2007, 03:57 PM
  5. Sharan TDI starting problems
    By ferrispedro in forum Archive posts
    Last Post: 22-08-2006, 09:37 PM
