Thread: New front shock absorbers
  1. New front shock absorbers
    Sep 2007
    Hey guys, my trusty Passat gives off 'pssst' noises from the front of the car as I drive over bumps and uneven surfaces. It's done 120k so it sounds like the shock absorbers are finished.
    Eurocarparts are offering Bilstein or Sachs as replacements? I don't want firm suspension, as what I have at the moment (OEM) are really good ride, soft and good cornering.
    Any one used any of these, or any other brand and how would you rate it?
    Thanks.
  2. Re: New front shock absorbers
    Apr 2007
    France
    12 Post(s)
    Before you buy some new ones, are you sure that's the problem. Try bouncing a front corner of the car a few times and see if it stops when you do.
    1996 Laguna 2.2D
    1977 MGB roadster
  3. Re: New front shock absorbers
    Norfolk
    If you are only replacing two shocks and not all four, I would only fit genuine ones from a dealer. Lot's of people will disagree with me though.
  4. Re: New front shock absorbers
    Apr 2010
    Ashford, Middlesex
    Quote Originally Posted by martin1810 View Post
    I wouldn't - I replaced the rear shocks on my last Passat (a B5 saloon) with aftermarket ones (Boge I think), and the effect on the handling was pretty disastrous to be honest - the car never felt 'straight' again (felt like it was crabbing up the road), and that coupled with other niggles made me get rid.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  5. Re: New front shock absorbers
    Sep 2007
    The car is so heavy, it hardly bounces!
    It does a slight squeaking noise when you lift the car and then drop it, doesn't move much but enough to hear that darn noise.
    I've always thought squeaky suspension is the shocks, am I miss guided?
  6. Re: New front shock absorbers
    Jul 2007
    TBH, it sounds more like the noise my bushes made at the front end before the suspension arms were replaced with the new, super-dooper uprated items.
    Try spraying the suspension with water then seeing if it still makes the noise, if not I would suspect its because the water has lubricated the worn bushes.
  1. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  2. Help changing the front shock of an Audi A6
    By gidimille in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-11-2009, 08:07 PM
  3. 1998 A4 Airbag Controller - need recode number
    By jhutchison in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-09-2008, 05:32 PM
  4. A3 shock absorbers
    By Niklock in forum Audi A3 - Archive Topics
    Last Post: 20-02-2008, 08:45 AM
  5. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
