Thread: Smoke Problem
  1. Smoke Problem
    Jul 2008
    Right this might be quite a long winded explanation:
    My A3 has had a new Cambelt, Head Gasket and radiator but its smoking abit, no smoke whilst its ticking over, no smoke when im driving unless i boot it.
    Ive heard it might be a valve seal problem (i know these werent changed when i had my head gasket done). So without having to take the head off and check the valve seals ive brought some fluid that i put in the petrol tank, which is ment to help the seals?
    Mainly i want to know is my diagnostic right?
    and has anyone used this fluid, mines castrol valve protection (i think).
    Or any other suggestions?
  2. Re: Smoke Problem
    What colour is the smoke? this can help you narrow down the areas to look at.
  3. Re: Smoke Problem
    Jul 2008
    well its a tint of blue in the smoke, but i think ive got it sorted with the valve seal proble so without taking the head off ive used some stuff that ive put in my oil, to hopefully sort my valve seals.
  4. Re: Smoke Problem
    Lets hope so. Blue smoke among other things tends to be oil mixing with the fuel before it burns. Piston rings being the first place to look. Either way good luck!
  1. Yet another white smoke on cold start - but maybe fixed?
    By richard_gomm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2009, 04:35 PM
  2. random overheating problem, no heat from a/c, please help!
    By rabby in forum Golf MK3 - 1993 - 1999
    Last Post: 23-11-2007, 10:38 AM
  3. Blue smoke, but strange symptoms
    By davidbr in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-10-2007, 10:03 PM
  4. Oil Pressure problem
    By j1borman in forum Passat - Archive Topics
    Last Post: 23-01-2007, 10:08 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
