Thread: power steering problem 1.9 tdi 02
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
  1. Unhappy power steering problem 1.9 tdi 02
    A6 1.9TDI 52 REG AVANT HAVING TROUBLE WHEN TURNING AT SLOW SPEED SOUNDS LIKE TRACTOR
    i have change the p/s pump, belt tensioner and the belt, and it is still the same, the belt is making more noise then the engine at tickover, lift the revs up a little and it is ok.....
  2. Wink
    May 2007
    knee deep in clunge
    14 Post(s)
    The alternator pulley clutch is seized and the belt will be jumping.The pulley is about £30 to £60 depending on the manufacturer of the alternator and you will need a 14mm spline socket to replace it(i think its 14).You can remove the alternator with out loosening the lock carrier,remove the viscous pulley and remove the alternator and remove the pulley.When they seize the pulley cant slip with the ribbed belt and the tensioner takes the strain and can snap off.
    2 0 0
  3. #3
    thank's changed the alt pully and now running perfect...
    May 2007
    knee deep in clunge
    14 Post(s)
    Great stuff.Did it surprise you,often overlooked is the old alt pulley.Regards Jon
  5. Re: power steering problem 1.9 tdi 02
    Sep 2007
    Plymouth
    Would anyone suggest I have same problem?
    To explain:
    Only started this week, when starting from cold, seems the power steering has started to groan, and only when I turn the wheel. When the car warms up the groan goes away. The actual steering itself feels normal.
  6. Re: power steering problem 1.9 tdi 02
    Sep 2008
    Chichester
    I've just bought a 2003 Avant 1.9 TDI and I think i may have this alternator clutch problem? I'd appreciate any help/confirmation from anyone who's experienced it...
    On full lock the steering makes a loud "intermittent squeak" (not the normal squeal I've had on other cars) and I've noticed that when reversing at very low speed there is sometimes some judder through the steering. Could this be the alternator pulley clutch?
    Eeyore
    A6 Avant 2.0 TDIe 2009 (Facelift)
    Not worth starting anything now...."
  7. Re: power steering problem 1.9 tdi 02
    When Turning At Slow Speed Sounds Like Tractor And The Belt Slips, Once The Revs Are Up, The Engine Is As Normal.
  8. Re: power steering problem 1.9 tdi 02
    Sep 2008
    Chichester
    Quote Originally Posted by a8 tech View Post
    The alternator pulley clutch is siezied and the belt will be jumping.The pulley is about £30 and you will need a 14mm spline socket to replace it(i think its 14).You can remove the alternator with out lossening the lock carrier,remove the viscous pulley and remove the alternator and remove the pulley.When they sieze the pulley cant slip with the ribbed belt and the tensioner takes the strain and can snap off.
    I read somewhere else on the forum that there's a special tool required to remove the pulley. Is that the case or is the 14mm spline socket all I'll need?
    Don't want to start "fiddling" until I know I have all the tools required!
    Eeyore
  9. Re: power steering problem 1.9 tdi 02
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by eeyore View Post
    Bump this thread this evening. I changed the alternator pulley on mine but can't remember now. Will check tonight for you should I remember.
    If I remember correctly I used a 14mm spline tool. I had this problem on my T5 too it is really common on VAG TDIs.
    Paul
  10. Re: power steering problem 1.9 tdi 02
    Sep 2008
    Chichester
    Bump!
    Eeyore
  1. Power Steering Fluid
    By s0niX in forum Polo - Derby - Lupo - Fox
    Last Post: 29-03-2007, 02:05 PM
  2. Power Steering noise
    By jshodgson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-01-2007, 06:20 PM
  3. audi 100 1990 power steering problem
    By tonos in forum 100 - 200 - Turbo - 100 S4
    Last Post: 08-01-2007, 11:27 AM
  4. polo power steering
    By banny in forum Polo - Derby - Lupo - Fox
    Last Post: 30-12-2006, 12:37 AM
  5. power steering loss when wet
    By shanecr in forum 80 - 90
    Last Post: 10-11-2006, 08:08 PM
