Thread: Key fob faulty ?
Results 1 to 10 of 13
  1. Key fob faulty ?
    May 2008
    Went to work today as usual. Forgot something which was in the boot so went back to car to take it out. Pushed the boot opening button but nothing. Tried to unlock the doors, but again nothing. Tried this again several times and noted everytime the red LED light on the key fob lit up, but no response from the car at all. Boot and doors remained locked.
    After trying this for quite a few minutes I heard the magic click, so grabbed the door handle quickly and it opened as usual. I then used the boot open button in the drivers door, took out what I needed, then closed the boot and door. Pushed the lock button on the key fob, again the red LED lit up, but no response from the car at all. It took several more attempts to get it to lock.
    Then when home time came it wouldn't unlock again. It took several attempts to get it to unlock. The car then started and drove as usual.
    I went straight to the VW dealer and got them to change the key fob battery. The parts person seemed unconvinced that this was the problem due to the age of the car, but changed the battery anyway - £2.63
    The car is only 3 months old from new, but the battery could be older I guess.
    They suggested if it happens again try the other key fob, which I now have just in case. Plus of course, the emergency plastic key which I didn't try today as I had nothing to help get the door handle cover off.
    Anyone else had this problem.
  2. Re: Key fob faulty ?
    Apr 2009
    Largs, North Ayrshire
    I had the same thing happen to me about a year ago. I arrived at a friends house but couldn't lock the doors. I tried everything but the fob would just not work. Took it apart, the light was still blinking too.
    I remembered when I had my previous car I changed the battery on the fob and accidentally dropped the battery therefore going past the golden 2 mins, so the fob didn't work. It had to be reprogrammed. I found the Astra owner's club forum and they said to reprogram it just put the key in the ignition and turn ignition on fully without starting the car and hold down the door open button for 10secs then switch off the ignition and the fob should be reprogrammed. Worked a treat. So I tried that with the Passat and it worked too. Don't actually know that it worked but the car locked and it hasn't happened since.
  3. Re: Key fob faulty ?
    Oct 2009
    bradford
    The plastic emergency key will take the cover off, there is a small slot underneath and the end fits in there and will pop it off.
  4. Re: Key fob faulty ?
    Norfolk
    Most garages can check if your key is sending a signal with a keyfob tester, the dealer can do a complete check with their diagnostic machine. At least that way you know if the key is working. The key will always start the car even if the door lock/unlock is not working. They are two different systems.
    How do you press the lock/unlock buttons with the key in the ignition.
  5. Re: Key fob faulty ?
    Dec 2009
    14 Post(s)
    Quote Originally Posted by martin1810 View Post
    I was thinking the same
  6. Re: Key fob faulty ?
    Up North
    Start by changing the battery. You can try the one out of the other key if you are quick enough. Mine was working fine one day, dead the next.
    They're only a couple of quid from Toolstation or Screwfix, no need to go to a dealer.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  7. Re: Key fob faulty ?
    May 2008
    Eh ?.
    Anyway, everything worked fine again last night after visiting the dealer and having had new battery fitted, and also was fine this morning until I got to work again. I work all over the place and yesterday was the first time I've worked on this particular site. Got back there this morning and had exactly the same situation - the fob not appearing to work, so I left the car unlocked. Went out at lunch time and again the fob still didn't work at all. As you say martin1810, the car will still start and drive fine. Once off site I had no problem, everything worked as usual, the fob performing perfectly.
    I can only assume there was some sort of interference blocking the fob signal where I was working. Could this be possible, and what frequency do they work on.
  8. Re: Key fob faulty ?
    Nov 2008
    Lincoln, UK
    Quote Originally Posted by johnloaderuk View Post
    Are there management comms radios where you work? I read that last year in the Lake District,there was a central locking/alarm anomily. Turned out to be interference from radios in use by waitresses at a local cafe!
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  9. Re: Key fob faulty ?
    Apr 2007
    France
    12 Post(s)
    Am I missing something here? The lock/unlock button is on the driver's door, so what's the problem?
    1996 Laguna 2.2D
    1977 MGB roadster
  10. Re: Key fob faulty ?
    May 2008
    Quote Originally Posted by dunkley201 View Post
    Probably there were, as I was working at fairly large site employing around 6,500 people. I was working at a major aircraft manufacturing plant, with radars on site for the control tower and all other associated radio and communication equipment on site, so the possibility of something interfering with the signal was potentially extremely high. Apparently the control tower work on 118.0 to 135.975 MHz. I have no idea what VW key fobs frequency would be.
    I parked in exactly the same visitors parking place as yesterday, with exactly the same problem. There were other VW's in the same car park, but away from mine and no one else had a problem. Now I've come away from the site all seems to be working fine again - so far.
  1. key fob problem
    By maxim123 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2009, 10:59 PM
  2. Please Help Central locking works fine but remote doesn't
    By john_richter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2009, 02:46 PM
  3. how to program a 3 button fob for 01 passat
    By explorer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 04:43 AM
  4. Remote Key fob 98 golf
    By abble in forum Golf MK4 - 1999 - 2004
    Last Post: 08-01-2008, 09:05 AM
  5. key fob/ central locking/immobiliser problems
    By adamoliver in forum Polo - Derby - Lupo - Fox
    Last Post: 04-12-2007, 08:56 PM
