Thread: Mot
Results 1 to 10 of 17
  1. Mot
    Banchory, Scotland
    Ok, Just back from MOT with four failure points, 3, i can fix no probs...The 4th, exhaust emission fast idle test failure not too sure about.
    On the 1st test CO: value actual was 0.490 % instead of 0.300 % - FAILED
    LAMBDA: value actual was 1.029, has to be within 0.970 - 1.030, so just inside the acceptable tolerances - PASSED
    On the 2nd test CO: value actual was 0.359 %, came down a little but still FAILED
    LAMBDA: value actual was 1.073, so FAILED this time
    Plugged in VCDS Lite & came up with no fault codes whatsoever.......
    I don't think there can be much wrong, any ideas folks ?
  2. Re: Mot
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    A cat failing?
  3. Re: Mot
    Pembrokeshire
    22 Post(s)
    what engine are we on about, and what year ?
  4. Re: Mot
    Gwent
    You can test the lambda sensors with a digital multimeter:
    http://www.12v.org/maintenance/repairs/o2sens.php
    May be worth checking the coolant temp sender for the ECU?:
    http://www.12v.org/maintenance/repairs/ect.php
    Both items can be out of spec but not 'failed' so would not show a fault code
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Re: Mot
    Banchory, Scotland
    Thanks guys, previous owner put new exhaust system on in Jan 2009, @ £520 i would hope the cat hadn't failed already
    I will test the sensors tonight....Thanks.
    Going back to the emissions would it be worth adding some sort of fuel additive before puting through the test again ?
    It's an 1995, ABC 2.6, V6 auto, engine,
    cheers,
  6. Re: Mot
    Oct 2009
    10 Post(s)
    Are you sure the £520 included a new cat though, I was quoted £500 for a system without a cat last summer, also '95 abc v6
    As it turned out I only needed a cat and found a nearly new one on a wreck,£40 lovely' and though my car is not running at it's best, it passed the mot clear just 2 weeks ago
    Stuart
  7. Re: Mot
    Pembrokeshire
    22 Post(s)
    i would give it a dose of forte petrol treatment, then drive it like you stole it for at least 10 miles, then get it retested while it is still nice and hot. if that doesnt do the trick, and there are no fault codes logged, and the airfilter, plugs and oil are all new, then it may well be the cat. as stuart has said, the exhaust may not have included a new cat, or it might be a sports cat that doesnt work very well.
  8. Re: Mot
    Banchory, Scotland
    Point taken....Just assumed that it would have been a complete exhaust system for that price
    I've gone down the route of treating the petrol & giving her a thrash before the MOT, recommended by a few folk....
  9. Re: Mot
    Banchory, Scotland
    Thanks folks....Passed the MOT no problem now
  10. Re: Mot
    Oct 2009
    10 Post(s)
    Well done, it's a weight off your mind when they clear these hurdles
  1. Teeside Audi
    By nortona6 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 14-03-2011, 07:12 PM
  2. Free Audi MOT ?
    By Dazzler01 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-07-2010, 04:52 PM
  3. FREE AUDI MOT - Has this now expired? ?
    By RickT in forum Chat - Anything with wheels
    Last Post: 22-03-2010, 11:24 AM
  4. MOT Failure - Emissions Kwik Fit!!!
    By chrisward103 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-01-2010, 07:05 PM
  5. Polo MOT failure on exhaust emissions
    By slund in forum Polo - Derby - Lupo - Fox
    Last Post: 28-01-2008, 04:31 PM
