Thread: Oil Pressure Switch
  1. Oil Pressure Switch
    Sep 2009
    uk
    I have a 1996 Audi A4 petrol;
    If I get an oil leak from the oil pressure switch where would I expect to see oil leak on the engine?
  2. Re: Oil Pressure Switch
    duncan89 Guest
    Hmmm - I think I have the same problem ... loads of oil coating the sump and gearbox of my Audi A4 - hard to know where its coming from. However, the highest point of the oil mess is the oil pressure switch, so I am going to change this, clean up all the mess and see what happens.
    To answer your question - oil gets everywhere - it does not evaporate like a water leak - just look for the highest point of oil mess in your engine, and you are near the source.
  1. Please Help Oil Pressure Light - 1.8T AEB
    By SilentBob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-09-2009, 01:31 PM
  2. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  3. How to replace Oil Pressure Switch?
    By mbohea in forum Golf MK3 - 1993 - 1999
    Last Post: 13-05-2008, 06:40 PM
  4. oil pressure problem
    By silverado in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-04-2008, 05:05 PM
