Thread: Passenger window front
  1. Angry Passenger window front
    May 2010
    bicester oxford
    Hi can some one help me please with 1.9 tdi 2000 passat
    my passenger window will not move .
    I took off my interior trim and checked my switches there fine
    when i press the switches the regulator / motor clicks but nothing else happens .
    I was told it was the regulator/ m,otor needs changed so i got one and tested it but it just clicks . Should the coq not move when switch is pressed? .
    Hope some one can help .!
  2. Re: Passenger window front
    Norfolk
    Sounds like you may have lost the main power feed to the motor. Check your fuses and check the wiring where it goes from the body to the door.
  3. Re: Passenger window front
    May 2010
    bicester oxford
    Quote Originally Posted by martin1810 View Post
    which fuse could it be?
  4. Re: Passenger window front
    Norfolk
    Sorry my mistake...All the window motors use the same fuse so it can't be a fuse. Looks like you may have to strip the door to test for 12v.
  1. 4 Motion soft suspension
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 09:25 AM
  2. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
  3. Passenger door window has disappeared!
    By greengeorge in forum Golf MK5 - 2004 - 2009
    Last Post: 01-10-2007, 05:15 PM
