Thread: Labels file for 2.0tdi 170
Results 1 to 10 of 15
  1. Labels file for 2.0tdi 170
    May 2010
    Livingston Scotland
    I am trying to log some data with my genuine vag com cable specificaly the measuring blocks 115 which should give me asked boost versus actual. WHen i do a scan or try this i get the message "redir fail" under the labels and it doesnt seem to have the measuring blocks i need.
    I am a novice with Vag com so was wondering if anyone had created a labels file for this or could offer any help? It seems others are manging to log this on the cupra and golf forums?
    Car is a B7 A4 2.0TDI Quattro.
  2. Re: Labels file for 2.0tdi 170
    Ambler, PA, USA
    What version of VAG-COM? Did you try one of the Beta versions? Could be we don't have the details on the TDI engine in your car - or it has been added just recently in one of the Beta releases.
  3. Re: Labels file for 2.0tdi 170
    May 2010
    Livingston Scotland
    hi there i am using release 908.2?
    its a ross tech usb hex +can cable. When i tried to use it on my TT 225 q it couldnt find the label for that either?
  4. Re: Labels file for 2.0tdi 170
    Ambler, PA, USA
    Please post an autoscan from both cars.
  5. Re: Labels file for 2.0tdi 170
    Magdeburg, Germany
    The TDIs have been on our TODO list for quite some time now and I hope to get to that before the next update/release. Can't promise a time frame though, sorry.
    About the TT, Bruce has already asked for the scan - that should clarify where we are on that as well.
    Sebastian @ www.Ross-Tech.com
  6. Re: Labels file for 2.0tdi 170
    May 2010
    Livingston Scotland
    thanks folks
    here is the scan fom the TT
    Tuesday,25,May,2010,19:52:17:06588
    VCDS Version: Release 908.2
    Data version: 20100326
    Chassis Type: 8N - Audi TT
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    VIN: TRUZZZ8N321033871
    Address 01: Engine Labels: Redir Fail!
    Part No: 8N0 906 018 H
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 01236
    TRUZZZ8N321033871 AUZ5Z0B5035115
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: Redir Fail!
    Part No: 8N0 907 379 H
    Component: ESP ALLRAD MK60 0101
    Coding: 0022544
    Shop #: WSC 01236 785 00200
    Address 08: Auto HVAC Labels: None
    Part No: 8N0 820 043 A
    Component: TT-KLIMAVOLLAUTOMAT D03
    Coding: 00041
    Shop #: WSC 01236
    Address 15: Airbags Labels: 8N0-959-655.lbl
    Part No: 8N0 959 655 A
    Component: Airbag Front+Seite 5000
    Coding: 01102
    Shop #: WSC 01236
    Address 17: Instruments Labels:
    Part No: 8N2 920 980 A
    Component: KOMBI+WEGFAHRS. M73 D11
    Coding: 05444
    Shop #: WSC 00726
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 C
    Component: HALDEX LSC ECC 0010
    1 Fault Found:
    00526 - Brake Light Switch-F
    27-10 - Implausible Signal - Intermittent
    Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
    Part No: 8N8 962 267 C
    Component: Zentralverrieg.,DWA D06
    Coding: 07918
    Shop #: WSC 01236
    1 Fault Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00010
    Shop #: WSC 01236
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 4B0 035 186 G
    Component: concert II GRO 0008
    Coding: 04302
    Shop #: WSC 01236
  7. Re: Labels file for 2.0tdi 170
    May 2010
    Livingston Scotland
    Here is the A4
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8EX7A131259 Mileage: 77320km/48044miles
    Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ
    Component: R4 2.0l PPD1.3 G 9971
    Revision: --H33--- Serial number:
    Coding: 0000172
    Shop #: WSC 66565 257 00032
    1 Fault Found:
    000665 - Boost Pressure Regulation: Control Range Not Reached
    P0299 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2144 /min
    Torque: 272.0 Nm
    Speed: 116.0 km/h
    68.25 %
    Voltage: 13.90 V
    Pressure: 2364.3 mbar
    Pressure: 1853.1 mbar
    Readiness: N/A
  8. Re: Labels file for 2.0tdi 170
    May 2010
    Livingston Scotland
    i suppose the main thing is that i want to check boost, requested via actual but cant find the measuring blocks? it should be 115 but this doesnt show correctly. it shows lateral acc and torque only?
  9. Re: Labels file for 2.0tdi 170
    Magdeburg, Germany
    For the time being you can use this generic list off our website for the TT 1.8T...
    http://www.ross-tech.com/vag-com/m_blocks/
    ...and on the TDI you should find your boost values in MVB 010/011:
    MVB 010: Charge Pressure Control
    MVB 010.1: Mass Air Flow (actual)
    MVB 010.2: Atmospheric Pressure
    MVB 010.3: Boost Pressure (actual)
    MVB 010.4: Accel. Pedal Pos. Sensor 1 (G79)
    MVB 010.1: Engine Speed (G28)
    MVB 010.2: Boost Pressure (specified)
    MVB 010.4: Charge Pressure Control Duty Cycle
  10. Re: Labels file for 2.0tdi 170
    May 2010
    Livingston Scotland
    brilliant thanks so much for the help
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  3. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  4. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  5. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
