Thread: Indicator Problem
Results 1 to 8 of 8
  1. Indicator Problem
    Taunton
    Can anyone help me,
    I have a VW Polo 1.3 CL J Reg (1991), full service history and its currently done 126K and counting and still going strong (touch wood!) and its my pride and joy. However a slight annoying problem has occurred as when wanting to indicate left. The indicator does not come on unless I push down hard on the indicator stalk. When not pushing hard down on the stalk it sounds like it an electrical problem as it makes an arching noise as if something is not connecting. I’ve had the underside of the steering wheel off and the indicator mechanism looks very complicated an expensive! Any advice as I fear this is might not be cost effective to fix considering the car is only worth 300quid. Please help as it’s a nightmare to parallel park without an assistant to hold the switch down!
    Many thanks in advance
    May 2007
    newcastle
    try and spray sum WD40 down into the stalk might just work
    Canada
    Quote Originally Posted by nick182 View Post
    DON'T spray wd40 on it. get some switch cleaner from halfords only about £4 a tin, it will etch the contacts clean, WD40 will work but make a mess. and enventully make the problem worst.
    Taunton
    Thanks chaps will pop into Halfords tomorrow on my lunch break and tell if it solves the problem. Many Thanks for your advice!
  5. Still not working
    Taunton
    Tried the switch cleaner fluid and still paying up however the crackling noise has stopped. I have read some of the other threads and might be a relay, any sugestions?
    May 2007
    17 Post(s)
    No, if the relay was at fault it would show up on the right hand side and the hazard lights too. Sounds more like a faulty switch to me.
    Regards - Jim.
  7. Re: Indicator Problem
    Hi I am having similar problem on my MK3 Golf two, I though the problem was cause by the indicating mechanism under the steering wheel, but by accident,i found the problem was caused by something else. Don't know if this happend to you as well.
    It works perfectly under normal circumstance, except when the foot break was pressed and then signal, the left indicator wouldn't come on until the break was released. I have tried it many time and this happened again and again. So I concluded the problem was related to the foot break. But no idea why. Anybody can think of a reason for it? I am going to try to replace the relay and see.
  8. Re: Indicator Problem
    Taunton
    Just to update readers of the cure to this problem.
    It was the indicator switch under the steering wheel. Went to a scrap yard and a replacement cost 25 quid and easy to replace.
    Just took off the central horn button then steering wheel (one nut) and indicator mech just pulled out. Inserted replacement and put everything back as was, very easy.
    Electrical cleaner spray worked a bit but the if you have the same problem just replace the unit itself.
    Hope the info helps
  1. Bora indicator problem
    By xerian in forum Bora - 1998 - 2005
    Last Post: 20-06-2008, 05:39 PM
  2. indicator problem
    By graham.hassall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2007, 03:42 PM
  3. Indicator problem
    By name43 in forum Passat - Archive Topics
    Last Post: 22-02-2007, 04:52 PM
  4. Indicator problem
    By san in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-02-2007, 03:53 PM
  5. 2001 A4 Indicator problem+
    By And1966 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-11-2006, 06:45 PM
