Thread: RNS 510 battery drain issue - solved?
Results 1 to 10 of 10
  1. RNS 510 battery drain issue - solved?
    Aug 2008
    I have been looking to upgrade my MFD2 to RNS 510 and saw all the problems with the CAN Gateway and batteries going flat if you have a pre 2007 Passat etc.
    Apologies if this has been discussed on another thread and I missed it...
    I was looking on ebay for the newer CAN Gateway and spotted this which may be of help to me and some of you:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...id=p2761.l1259
    on the face of it, it seems like the ideal solution - and cheaper than a new gateway without all the coding crap on VAG COM or whatever. Does anyone know if this will work, or the other way and cause more problems.
  2. Re: RNS 510 battery drain issue - solved?
    Oct 2009
    Staines, UK
    I thought a new CAN gateway was about £100 from the dealer anyway?
  3. Re: RNS 510 battery drain issue - solved?
    Aug 2008
    my dealer quoted £123 and that was supply only - then they or someone else would need to code it with VAG COM.
    They had no idea there was a battery drain issue and didn't know about changing or what a CAN gateway was (unbelievable) - more like fit the thing and get a flat battery, bring it in, £60+ per hour to find problem and then change and code gateway thank you very much.
    They didn't seem to want to help on what part number gateway I need for latest firmware - when they fit the sodding things in their cars!!
    If this other adapter works and is ok then that saves a whole lot of trouble in my opinion - IF it is as good as it says 'on the tin' .
  4. Re: RNS 510 battery drain issue - solved?
    DSG4ME Guest
    Get an aftermarket unit, why pay £1500 for a sat nav stereo, £900 will but you a peachy Pioneer or Kenwood unit, or if you really wanna save some money get the Xzent Inphase unit for £380 that does sat nav and everything else as well.
    http://www.caraudiocentre.co.uk/prod...20_p-24045.htm
  5. Re: RNS 510 battery drain issue - solved?
    Aug 2008
    Well I went for the 'Anti Battery Drain' adaptor lead as mentioned previously.
    Works an absolute treat!!
    Saves all the cr*p of getting the right gateway and getting in coded for some.
    Just plug your loom into it, then the adaptor loom into the RNS 510 - not forgetting to try the cd/ipod for sound quality 1st before install in case you need to swap wires 2+3 (as other threads)
    Bit of a squeeze to tuck loom gateway and connector block away but not to bad.
    I have now fitted a RNS 510 with this adaptor lead and it was all a doddle.
    RNS 510 has Firwmware 2720, Maps 6.1 with Speed Camera locations installed on Hard Drive, DVD in motion enabled.
    The car also had a Stage 1 Custom re-map done at Jabba Sport nr Peterborough done as well - took the bhp up to 180bhp.
  6. Re: RNS 510 battery drain issue - solved?
    Mar 2009
    York
    tdi sport - that's great news. Not thinking about upgrading any time soon, but if I do, then I know there's a simple solution to the problem. I understand this would also work for the RNS310?
    Thanks.
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  7. Re: RNS 510 battery drain issue - solved?
    May 2008
    Nice that it works I guess. I went for the new CAN gateway though, £60 from Ebay.de and it is easy to fit yourself - you really don't need to be paying dealers a fortune for simple stuff like this.
  8. Re: RNS 510 battery drain issue - solved?
    Nov 2012
    Norway
    [QUOTE=tdi sport;531829]Well I went for the 'Anti Battery Drain' adaptor lead as mentioned previously.
    Where did you get the adaptor?
    Liam
  9. Re: RNS 510 battery drain issue - solved?
    Dec 2012
    west yorkshire, UK
    There is an even easier fix its software. I got it from ebay member when I bought my rns510.
    the only downside was that after the software modification is done using a cd the time does not display on my rns510 version H when you turn the unit of while the car is still running.
  10. Re: RNS 510 battery drain issue - solved?
    Dec 2012
    west yorkshire, UK
  1. How To Remove battery without removing windscreen cowling & drain plenum, inc TDi
    By cazyp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2014, 03:03 PM
  2. Getting at the drain under the Passat battery
    By swampman in forum Volkswagen
    Last Post: 22-12-2009, 12:30 PM
  3. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  4. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  5. passat tdi battery drain
    By andycampers in forum Passat - Archive Topics
    Last Post: 18-11-2007, 04:37 PM
