Thread: RCD210 radio signal
Results 1 to 10 of 12
  1. RCD210 radio signal
    Feb 2010
    uk
    Hi all..
    Have been having an issue with the RCD210 with respect to FM stations. Particularly the BBC -radio 1/2. The signal keeps dropping and the sound quality is rather poor when the car is in motion. I never had this problem with any of my previous cars so I presume either the quality of the components/RF circuit design is crap.. or that the antenna itself is weak as in most cases when the car is stationary a decent quality output is obtained.
    Would anyone have any experience/advice on whether replacing the headunit would make a difference to this ? Or is the poor signal inherently due to the antenna design.. Cheers!
  2. Re: RCD210 radio signal
    May 2009
    Edinburgh
    You have tuned it properly? Might sound like a daft question but you never know.
    2010 Focus ST-3
  3. Re: RCD210 radio signal
    Feb 2010
    uk
    Yes, tried that a few times thinking that might well be the case but the stations are correctly picked up. Seems to be an issue when driving only. TP is off too.
    Anyone with a RCD310 having similar issues..
  4. Re: RCD210 radio signal
    Steve_D Guest
    I don't listen to R1 but I get a problem on R2 whatever car I'm in - sound disappearing for a split second, mixed with a short burst from some other channel.
  5. Re: RCD210 radio signal
    Feb 2007
    Quote Originally Posted by markus_bms View Post
    On my RCD310 i do get poor reception in a certain area but thats the lack of signal, and not radio itself. Not surprising as the only way we can get TV is by satellite, no terestial signal even though now supposedly an area with digital TV broadcasts.
    Sounds like your aerial connection might be a bit iffy - i'd pull the headunit out and double check its connected properly.
    2010 Golf Mk6 TDI105 SE - now departed, replaced with A3 Sportback
  6. Re: RCD210 radio signal
    Feb 2010
    uk
    Yes, i guess that's what i'll have to check out. Anyone done this with the RCD210 and got any links for the photos
  7. Re: RCD210 radio signal
    Steve_D Guest
    This thread is for a RCD310 but it should point you in the right direction.
    https://www.vwaudiforum.co.uk/forum/s...hlight=sat+nav
  8. Re: RCD210 radio signal
    Feb 2012
    Liverpool, UK
    I have recently upgraded the factory fitted rcd210 to an rcd 310 and have since experienced the same issue you described! The rcd 210 only requires 1 fm input and when factory fitted 1 fm antenna is installed! The rcd 310 requires 2 fm inputs (I only have 1)! The link below shows the item required to fix this issue but is not available in the uk!?!
    http://www.amazon.com/gp/product/B00...=0&*Version*=1
  9. Re: RCD210 radio signal
    Feb 2012
    Liverpool, UK
  10. Re: RCD210 radio signal
    Aug 2011
    Kidderminster
    I had (have!) problems with reception as well... I took it back and they replaced the whole radio, but the new one is just as bad... I don't think that its the radio, its the ariel. A booster seems the only solution?
  1. Integral Bluetooth radio for A4
    By Gary M in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2010, 03:45 PM
  2. Question Radio signal problems ? Concert
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-11-2009, 10:42 PM
  3. no signal radio aerial
    By hatter in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-10-2009, 07:31 PM
  4. Please Help Radio signal disappeared - Alarm going off!
    By randall977 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-05-2009, 10:35 PM
  5. Symphony Radio signal problem
    By jupiter8 in forum Audi A4 - Archive Topics
    Last Post: 04-09-2007, 12:58 PM
