Thread: Few faults thrown up by VCDS
Results 1 to 10 of 10
  1. Few faults thrown up by VCDS
    May 2010
    Glasgow
    Alrighty, 1st post guys so take it easy
    I've got a 05 plate Mk5 Golf, TDi 140bhp, remapped to 175bhp.
    Over the past year or so I've had a few problems with the car, with the engine light on. About 8 mths ago I had a problem with the EGR which was throwing up the code:
    19559 motor for intake manifold flap v157 malfunction P3103.
    Ever since the "Emissions workshop" message and the engine light has been on, i've noticed a considerable drop in power from the car. I got the EGR replaced around 2 months ago and was hoping that this would fix it but the mechanic told me that due to the fact that I had ran it so long without replacing the EGR, i now need a throttle body for it. The engine light still won't go off. Is this possible as i don't wanna get ripped off.
    The car also goes into limp mode on the motorway if I give it a good bashing. Bloody struggles to overtake 18 wheelers when in limp mode.
    Also the mechanic told me there's a fan fault. The fan's not letting my engine warm up. Not a big problem in the summer but can cause burnout to the engine in the winter. Couple hundred quid for 2 fans ive been told.
    I decided to get my car scanned by vag-com yesterday and here's what it threw up.
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FM HW: 028 101 190 3 begin_of_the_skype_highlighting 028 101 190 3 end_of_the_skype_highlighting
    Component: R4 2,0L EDC 0000SG 6179
    Revision: 12345678 Serial number: VWZ7Z0D1261505
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    4 Faults Found:
    19558 - Motor for Intake Manifold Flap (V157): No Signal
    P3102 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00000100
    Torque: 0.0 Nm
    Torque: 354.0 Nm
    19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
    P3101 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00000100
    Torque: 0.0 Nm
    Torque: 354.0 Nm
    17075 - Fan 1 Control Circuit: Short to GND
    P0691 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00000100
    Temperature: 81.9°C
    Duty Cycle: 9.6 %
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 000 - -
    Freeze Frame:
    RPM: 2268 /min
    Torque: 148.0 Nm
    Speed: 119.0 km/h
    Load: 32.2 %
    Voltage: 13.98 V
    Bin. Bits: 11000000
    Absolute Pres.: 1744.2 mbar
    Absolute Pres.: 2193.0 mbar
    Readiness: 1 2 0 0 0
    I'm hoping someone can help - and if the symptoms i've had with the car match the faults found on the log above, and if theres any cost-saving solution to the problems?
    Appreciate any help.
  2. Re: Few faults thrown up by VCDS
    all of these faults, I presume, have arisen following the remap?
    did the remapper perform a diagnostic test prior to completing his work?
  3. Re: Few faults thrown up by VCDS
    May 2010
    Glasgow
    Quote Originally Posted by Eshrules View Post
    I'm not sure if he ran a diagnostics mate. The remap was done around April 2008 so it's been a couple years, and yes, the problems have occurred after the remap.
    The engine light and EGR fault didnt appear until around August 2009 so a good 16 mths until after the remap
  4. Re: Few faults thrown up by VCDS
    Norfolk
    You need a new mechanic. This is a well known problem. The antishudder valve normally fails and jams which blows the fuse which stops the fan working as well. This is all part of the egr so you have to replace that. The overboost may be a different problem but can be related. Change the egr, fix the fuse, reset codes and see what codes come back....
  5. Re: Few faults thrown up by VCDS
    May 2010
    Glasgow
    Quote Originally Posted by martin1810 View Post
    You need a new mechanic. This is a well known problem. The antishuder valve normally fails and jams which blows the fuse which stops the fan working as well. This is all part of the egr so you have to replace that. The overboost may be a different problem but can be related. Change the egr, fix the fuse reset codes and see what codes come back....
    Hi Thanks for the reply mate. The EGR's been replaced a couple months back.
    And wht do you mean by "fix fuse reset codes". How do I fix them mate?
    Audi A4 S Line Special Edition 170bhp
  6. Re: Few faults thrown up by VCDS
    Pembrokeshire
    22 Post(s)
    i think he means fit a new fuse, and clear the codes.
  7. Re: Few faults thrown up by VCDS
    May 2010
    Glasgow
    cheers mate, theres a halfords down the road from my work. MY cars at home right now. Can i pick one of these fuses up from there?
  8. Re: Few faults thrown up by VCDS
    May 2010
    Glasgow
    Alright mate, i've fitted a new fuse. Do i have to clear the codes to notice a difference? No access to VAGCOM for a couple days.
  9. Re: Few faults thrown up by VCDS
    May 2010
    Glasgow
    any ideas guys? thanks
  10. Re: Few faults thrown up by VCDS
    Norfolk
    You need the codes cleared. Run for a few days and then code read again. That way you can see what codes are current. I think you may have turbo vanes sticking but you need the new read to give you a clue.
  1. A6 C6 VCDS Changes - Post & Pre Facelift
    By MFGF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2022, 09:33 PM
  2. VCDS OR VAG CAN Commander
    By Tariq Malik in forum VCDS - Help Requests
    Last Post: 12-03-2010, 03:02 PM
  3. VCDS Apprentice
    By johnvw in forum VCDS - Help Requests
    Last Post: 10-03-2010, 10:32 AM
  4. Igntion angle 22% and Fuel Pump Relay VCDS faults
    By headache56 in forum VCDS - Help Requests
    Last Post: 19-08-2009, 06:32 PM
  5. 1st Locked out, now dead batt - plz help!
    By xouser8334 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-07-2009, 03:25 PM
