Thread: clutch rumble noise ?
  1. clutch rumble noise ?
    Mar 2008
    Hello there,
    I have recently purchased a 1.9 tdi on a 56 plate with just under 120k on the clock. It has just started making a strange noise when on tick over, you can hear it easily outside the car. The noise is probably best described as sounding like a pulley or pump with shot bearings.
    However when you press the clutch the sound goes away - when you release it comes back and you can feel the vibration through the pedal.
    I have done a bit of research and fear it could be the DMF, does anyone else have any ideas given the symptoms - I know it's difficult going on peoples descriptions!
    Many thanks
    Alastair
  2. Re: clutch rumble noise ?
    DSG4ME Guest
    That can also be a layshaft bearing as well.
  3. Re: clutch rumble noise ?
    Mar 2010
    salisbury wilts
    sorry to say but it does sound like the dual mass flywheel.
  4. Re: clutch rumble noise ?
    Norfolk
    If you can feel it through the clutch pedal it is the DMF/clutch combination. The DMF will make a slight chattering noise at first. You could be feeling the clutch lining breaking up...They do that. Have a look at my pic....That.'s a clutch plate with no friction material left. Don't ignore it. If the DMF fails completely it can smash the gearbox case or even set the car on fire (according to VW).
  5. Re: clutch rumble noise ?
    Mar 2008
    thanks gents my worst fears probably confirmed. At what stage does the fire kick in 'cos that sounds like a good option! what kind of money can I expect to pay an independant to do the complete job do you think?
    thanks again
    Alastair
  6. Re: clutch rumble noise ?
    Norfolk
    I have never heard of a fire but it worried VW so much they sent out a bulletin about it so I guess it did happen. Clutch and DMF is just under £400 from GSF or Eurocarparts and about the same to fit. I have heard of people having it done for £650 all in. Dealers charge up to £1500...
  7. Re: clutch rumble noise ?
    Mar 2008
    Thanks Martin,
    got a quote today, £700 from an independent and £1100 less 15% from VW
    Will be going down the indie route me thinks.
    Cheers for your help
  1. Question Gt tdi wheel noise HELP (long story)
    By Buzzoff in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2013, 06:14 AM
  2. Question Noise when putting clutch in/disengage clutch
    By Felix in forum Golf MK4 - 1999 - 2004
    Last Post: 31-10-2009, 06:39 PM
  3. Clutch Noise - Advice Needed
    By Timk in forum 80 - 90
    Last Post: 27-03-2009, 08:12 PM
  4. Clutch (release bearing) noise... pls help!
    By Avant_Dave in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-09-2007, 11:07 PM
  5. Intemittent loud noise from radiator area
    By TBird1 in forum Passat - Archive Topics
    Last Post: 09-02-2007, 03:20 PM
