Thread: Bad starting T5 130
  1. Bad starting T5 130
    May 2010
    Rye
    T5 130 2006 very poor starting. Sounds like it fires on one or two cylinders. Will start by keeing the starter going. Have replaced glow plugs which were in fact all ok.
    Is there a fuse or relay for the glow plugs?
    Where are they?
  2. Re: Bad starting T5 130
    what is the engine code
  3. Re: Bad starting T5 130
    May 2010
    Rye
    Engine number is: AXD 135226
    Should add, starts fine when warm
  4. Re: Bad starting T5 130
    the glow plug relay is fused by a 60amp fuse in the fuse box in the engine compartment,the glow plug relay is in the electronics box in the engine compartment,with the ambient temp now the engine should start ok even without the glow plug system,you need to check the PD values with the engine cold
  1. GOLF 1998 Mk4 GT TDI (110) - bad starting
    By pdpaxm in forum Golf MK4 - 1999 - 2004
    Last Post: 05-08-2009, 08:42 PM
  2. broken bonnet pull cable on t5 2.5 130
    By tone_rmz in forum The Commercial Range
    Last Post: 05-07-2009, 05:15 PM
  3. Question Starting Problem GT Tdi 130 52 plate
    By Munsterman71 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-06-2009, 10:24 PM
  4. Bad cold starting - old fuel?
    By DubDick in forum The Commercial Range
    Last Post: 08-05-2009, 09:44 AM
  5. bad starting polo
    By bogdan191084 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 08:43 PM
