Thread: Weeping turbo and leaking radiator
Results 1 to 9 of 9
  1. Weeping turbo and leaking radiator
    newb1e Guest
    Just want some opinion from you guys.
    On the way to Asda the other day, the low coolant warning light came on. Checked and found coolant had gone down to 'low'. I didn't wanna mix it with other supermarket coolant so I topped it up with water. Got home and it gone back to 'low' again.
    I took the car to VW central specialist garage for a pressure test the following morning. On ramp they found there's a leak on radiator and what they called weeping turbo. Basically they said the turbo is leaking tiny tiny amount of oil which is normal as the garage's owner's passat has it and many audis have this. They reassured me its a very common problem and i shouldnt worry about it.
    you guys heard of this? the oil level has been fine since i bought it 1 month ago.
    I had to travel somewhere so they stuck some undiluted quantum coolant in so whenever it goes down, i can top it up with water. After 60 miles of motorway and city driving plus hours of parking, the coolant level seems to be fine??!! has the leak gone or something?
    If there is a hole, i think it's tiny. Are there any aftermarket radiator sealant i can use to patch it up? The guy quoted £210 for new radiator plus fitting, which i think is quite reasonable but if i had the choice, i rather not.
    thoughts guys?
  2. Re: Weeping turbo and leaking radiator
    Mar 2009
    York
    There is a known weakness in the connections at the side of the radiator, and this is where the leak will be from - I had exactly the same coolant issue, and luckily for me it was replaced under warranty. You can try using solutions that aim to 'plug' the leak (think ********* have some), but tbh I think you're looking at a new radiator anyhow.
    Can't help you with the turbo issue, however specialists are usually very good and very honest (which is how they get business away from dealers). If they say it's OK then I'd be tempted to believe them - unless anyone else knows differently?
    Thanks.
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  3. Re: Weeping turbo and leaking radiator
    Norfolk
    I would get the radiator replaced. Don't stick muck in it. That way the job is done and you can forget it. Weeping turbo ???? What's that meant to mean. All turbo's leak some oil from the air pipes but the oil pipes shouldn't leak. Might be an idea to ask where the leak is.
  4. Re: Weeping turbo and leaking radiator
    newb1e Guest
    i think it could be what you've described - oil from air pipes. is that a common problem then? potentially serious?
  5. Re: Weeping turbo and leaking radiator
    Norfolk
    Quote Originally Posted by newb1e View Post
    That's not a problem....that's normal for a turbo.....they all do it.
  6. Re: Weeping turbo and leaking radiator
    newb1e Guest
    did they design it to be like that? cus to me, anything leaking is not good. haha.
    it made me think my car was abused before i bought it. phewww...
  7. Re: Weeping turbo and leaking radiator
    May 2009
    Blackburn, lancashire.
    Me thinks your paranoid!!
    Working too hard.
    Black 2.0 140bhp SE Estate/Private plate/Privacy glass/17in alloys/Bumper protector/Meta parking sensors/Travall dog guard/Barjo tailgate guard/Vent lock/Boot liner/Philips X treme bulbs/Tailgate sun blind/Thule roof bars and 591 Prorides.
  8. Re: Weeping turbo and leaking radiator
    Nov 2008
    Lincoln, UK
    You try designing a turbo seal that rotates at mega thousands of rpm, with exhaust gas temperatures & pressures on one side of the seal and engine oil pressure on the other, yet allowing sufficient clearance to spin. I am sure it will always leak a little, even with a new turbo!
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  9. Re: Weeping turbo and leaking radiator
    newb1e Guest
    thats a very good explanation, thank you!
    a night out to nandos just now, coolant still at 'max' level?! the leak is gone! (i wish)
  1. Please Help Turbo Boost Pipe Seals Leaking
    By Sloggs in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-06-2010, 04:10 PM
  2. Turbo leaking oil
    By Dannyg81 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2010, 06:57 PM
  3. 98 gt tdi turbo leaking - Newbie.
    By hyla75 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2008, 09:25 AM
  4. Noise when turbo spinning accompanying power reduction.......
    By jamesmc1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2007, 07:50 AM
  5. Passat 130Tdi turbo problems
    By Jon Tallis in forum Archive posts
    Last Post: 05-06-2007, 07:52 AM
