Thread: Climate control reset??
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Climate control reset??
    Dec 2009
    Birmingham UK
    Does anyone know the correct procedure for resetting the dual zone climate control system on a C5 A6 Allroad? Mine is cooling the air fine (after a regas) but the driver's side is failing to mix the air correctly i.e. it's always warmer than the passenger side despite being set to the same temp.
    When I tinker with the temps it sometimes fools the driver's side into more cooling but I think the calibration is out or something.
    I want to try a reset to see if that corrects things before messing around with dampers and motors etc. but not sure exactly how to do it via VAG.com.
  2. Re: Climate control reset??
    2013 Post(s)
    Do you have a registered copy of VAG-COM?
  3. Re: Climate control reset??
    Dec 2009
    Birmingham UK
    No but a colleague does. He's happy to help me.
  4. Re: Climate control reset??
    2013 Post(s)
    Go into "08 auto HVAC", then "basic settings" and then "group 001", click "go" and you will hear the motors moving about. There is also an output self test. Before you start, check for fault codes and then print off any that are there before clearing them, if the same codes return, the relevant flap motors will need replacing.
  5. Re: Climate control reset??
    Dec 2009
    Birmingham UK
    Many thanks. I'll give it a try and keep fingers crossed!
  6. Re: Climate control reset??
    Jan 2010
    Lincolnshire
    Sorry for posting this on your thread but as its air con related I thought why not,the question is once you have set the temp to LO and put the fans on is that the air con on? Having only owned the car for 3 months this is the first weather where I can try it out lol.
    A6 3.0ltr v6.
    SE Quattro.
  7. Re: Climate control reset??
    Jun 2007
    If you turn Econ Off. Regardfs Peter
  8. Re: Climate control reset??
    Jan 2010
    Lincolnshire
    Quote Originally Posted by Peter D View Post
    Thanks Peter again
    A6 3.0ltr v6.
    SE Quattro.
  9. Re: Climate control reset??
    May 2007
    you don't need to set temp to 'LO'
    just press the auto, so as Peter says you loose the ECON light.
    set the temp to what you would like the cabin at, say 20 degrees.
    Air con will come on till cabin temp reaches 20 degrees, and then switch off.
    Fan speed will vary dependant on how far from desired temperature you are.
    You have full climate control, so it is automatic. Cheaper to run than straight Aircon, and much more civilised
  10. Re: Climate control reset??
    Dec 2009
    Birmingham UK
    Anyway - back to my original problem...!
    Tried a couple of things - disconnected battery to reset ECU. No improvement. Got specialist to take a look yesterday and for some reason the climate control module wouldn't allow interrogation?? Also had to have a regas as the level was low (despite regas 2 months ago...) - prob leaking somewhere or didn't get the full regas last time.
    Seems to be much better but of course weather is cooler - we'll see.
    Anyway - I'm aware I can replace the CC module but have been told the part number ie last two letters must match exactly? Anyone know if this is true? Or can I just get one off ebay for a C5 A6?
  1. Replies: 1
    Last Post: 07-03-2010, 08:46 AM
  2. Please Help A4 2001 Climate Control Unit
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2009, 05:11 PM
  3. Please Help Battery + Climate Control Unit + Engine + What's next?
    Last Post: 02-05-2009, 07:39 PM
  4. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
