Thread: Climate control reset??
Results 11 to 20 of 22
  1. Re: Climate control reset??
    Contact www.BBA-Reman and see if they test/repair these. Regards Peter
  2. Re: Climate control reset??
    Dec 2009
    Birmingham UK
    Many thanks Peter - very useful!
  3. Re: Climate control reset??
    Dec 2009
    Birmingham UK
    Update - tried the VAG.COM reset procedure and all seems to be working normally. Nice chilled air from all vents.
    However - I think now I have a problem with the auxiliary condenser fan not activating i.e. at standstill or in heavy traffic the cooling is poor and on one occasion knocked out the compressor completely. I assume there must be a thermostatically controlled switch that's failed and hence the fan isn't cooling the condenser when required??
    Anyone know of this problem and/or where the switch is located?
  4. Re: Climate control reset??
    Jun 2010
    Anston England
    Quote Originally Posted by Kyojitsu View Post
    Anyway - back to my original problem...!
    Tried a couple of things - disconnected battery to reset ECU. No improvement. Got specialist to take a look yesterday and for some reason the climate control module wouldn't allow interrogation?? Also had to have a regas as the level was low (despite regas 2 months ago...) - prob leaking somewhere or didn't get the full regas last time.
    Seems to be much better but of course weather is cooler - we'll see.
    Anyway - I'm aware I can replace the CC module but have been told the part number ie last two letters must match exactly? Anyone know if this is true? Or can I just get one off ebay for a C5 A6?
    Why do you think you can use aircon in hot weather only?
    Aircon is what it says and can be used at any temperature,it is the ideal way to demist your car in the winter months and,FWIW aircon should be run for at least 15mins.every month to help keep the seals lubricated.
    Regards.
    Col
  5. Re: Climate control reset??
    Dec 2009
    Birmingham UK
    I don't - it's just that hot weather more clearly reveals a problem with cooling.
    Given the climate control will reduce cooling effect proportionate to reducing outside air temp, the colder it gets the harder it is to test the system's working properly.
    So a good hot day tends to reveal problems like no other!
  6. Re: Climate control reset??
    Sep 2008
    I've got the same problem. Did you manage to sort it out?
  7. Re: Climate control reset??
    #17
    7 Post(s)
    Had this on my old Passat and solved it. Look at this thread for all the information I gleaned, the A6 is the same if it is a 1.9.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=43055
    That thread describes how I checked and eliminated the fuses and relays and then pinpointed the resistor pack.
    However have you tried helping the fan start on its way?
  8. Re: Climate control reset??
    #18
    Dec 2009
    Birmingham UK
    Very interesting - thank you. I was told a new fan and control module would be £180 plus VAT so a resistor pack seems more attractive! Hadn't even considered it. I've also got no idea where it's located - presumably not to far away from the fan motor? Perhaps mounted on the rad itself?
    I've not tried giving it a spin as I hadn't realised there was low speed operation on start up. Worth a try.
  9. Re: Climate control reset??
    #19
    134 Post(s)
    2014 Post(s)
    Climate control cars have a transistorised fan controller, cars with a four speed blower switch have a resistor pack, both are located in the air box downstream of the fan so as to keep them cool.
  10. Re: Climate control reset??
    #20
    7 Post(s)
    Not so sure there.
    Both my B5.5 Passat and C5 A6 had climate control, both had the same resitor pack.
    Both cars were 1.9 (AWX) TDI's.
    The resistor pack is located on the underside of the passenger front chassis leg and requires the front end to be in the 'lock position to remove.
  1. Replies: 1
    Last Post: 07-03-2010, 08:46 AM
  2. Please Help A4 2001 Climate Control Unit
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2009, 05:11 PM
  3. Please Help Battery + Climate Control Unit + Engine + What's next?
    Last Post: 02-05-2009, 07:39 PM
  4. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
