Thread: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
Results 1 to 10 of 38
Hybrid View
  1. Question Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Sep 2008
    I recently wrote a thread on how my car was very lumpy and juddery between 1600rpm and 2200 rpm. Yesterday i had the car on vagcoms live data which told be after 15 mile motorway driving and 15 mins idling the coolant temp was still only 71 degrees. Diagnosing this as a possible faulty coolant temp sensor i was wondering if this could cause the car to run lumpy/judder at the above revs??? The sender is reading but the temp gauge only goes max to 75ish never does it reach 90 degrees which im now told it should. Could anyone help me on this situation please??? I took the connector off the sender and it changed things but still ran quite lumpy Please help!!!
  2. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    you need to actually measure the engine coolant temp as it may in fact not be heating up due to a faulty stat. You could put a peice of cardboard over 75% of the rad and see if the temp goes up to 85/90. If it does then I suspect the stat has failed. Report back and tell up your engine code, it is on the ID label in the Spare wheel bay. Regards Peter
  3. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Oct 2005
    Peter's got you on the way to diagnosing the issues.
    To answer the question in the thread title, yes a faulty CTS will cause fluctuating/lumpy idle.
  4. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Sep 2008
    Hi there, Thanks for the fast reply. The engine idles like a dream no erratic reving etc at all the only problems i get at all are the juddering/lumpiness at 1600-2000rpm. I am getting the temp sensor changed today so hopefully this will solve it other than that i shall meanwhile try and do what peter said and put some cardboard in front of the radiator. I just dont understand the juddering as it is so annoying and im only getting 28mpg is this normal???
  5. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Do you have a multi meter that measures resistance and what is the engine code. Regards Peter
  6. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Sep 2008
    Hi there peter, Im afraid i dont have a multimeter but i know the engine code is AYM!!!
  7. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Mar 2013
    Norfolk
    Hi there,
    i know it was a while ago for you but my 2002 A4 is having the same symptoms as yours did. I'm changing coolant temp sensor and stat tomorrow night. Just wondered if it made engine run a bit better as I'm thinking it might be over fuelling because engine is or it thinks it is running cool.
    I basically get slight judder when engine is under load between 1600 and 2200rpm like you did. Mpg is down a bit to.
  8. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Mar 2013
    Norfolk
    Quote Originally Posted by graemer147 View Post
    Hi there,
    i know it was a while ago for you but my 2002 A4 1.9 tdi 130pd is having the same symptoms as yours did. I'm changing coolant temp sensor and stat tomorrow night. Just wondered if it made engine run a bit better as I'm thinking it might be over fuelling because engine is or it thinks it is running cool.
    I basically get slight judder when engine is under load (pulling away) between 1600 and 2200rpm like you did. Mpg is down a bit to. Idles fine to!
    thanks Chris
  9. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Feb 2013
    Ellesmere, Shropshire
    Hi, newbie here! I have an issue with my cts too, i hope :-/. My temeprature gauge doesn't read at all and the car can also be awkward to start when warm, plus my mpg after 100 miles of mixed driving is only 26. Is this normal?
    Cheers Todd
  10. Re: Can a Faulty Coolant Temp Sensor Cause Judder/Lumpy engine 1600-2000 rpm???
    Ireland
    Just posted up a similar issue this morning on my avf a6. Hope it's not the stat as I just changed timing belt etc yesterday!!!
    Coolant temp sender ordered as my temp gauge never goes above 70-80....
    love to hear how others have gotten on after changing
    Damien
  1. Balance of power shifts for 2011 model year audi q7
    Last Post: 17-04-2010, 10:06 PM
  2. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  3. Yet another white smoke on cold start - but maybe fixed?
    By richard_gomm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2009, 04:35 PM
  4. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  5. '03 Ibiza 1.4 16v - faulty coolant temp sensor
    By Sam in forum Ibiza - Cordoba
    Last Post: 06-11-2007, 02:37 PM
