Thread: touran- no response from throttle pedal following gear change.
  1. touran- no response from throttle pedal following gear change.
    May 2010
    Harrogate
    105bhp Touran 2004 - eng code AQM.
    Car has developed a fault where following a gear change, up or down, there is no response from throttle pedal, car just goes into idle. The problem is intermittant and can run fine for a while.
    Garage ran diag test and came up various possible components with a code G40 - cam sensor, crank sensor , thrust sensor and throttle position sensor.
    A thrust sensor was recently fitted and now a new pedal and sensor has been fitted, however the problem still persists.
    Any of you guys come across similar problems? any help would be much appreciated.
  2. Re: touran- no response from throttle pedal following gear change.
    135 Post(s)
    2036 Post(s)
    I have had to fit a few new throttle pedals to Touran’s, it appears to be a common problem but it has not solved your issue.
    Unfortunately, without a numbered list (either VAG or P codes) of the current stored codes, it is impossible for me to help any more.
  1. 5 speed gearbox selector problems
    By firelizard in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2010, 02:51 AM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Throttle Pedal lose and pops up!! :S
    By Minda16 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-02-2008, 02:41 PM
  4. FIRST PICTURES OF NEW TOURAN REVEALED BEFORE PARIS SHOW
    Last Post: 13-09-2006, 07:14 PM
  5. Touran on Top Gear
    By Touran Man in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2004, 09:11 PM
