Thread: 2001 s3 air con problem
  1. 2001 s3 air con problem
    i have had gas checked and is ok when i turn on ac internal fan blows ambient air looked at compressor pulley spinning but seems as though the clutch thingy on end of compressor is not turning think it is supposed to ? any idea what to check next air con fuse ok is there any relay to check ? also saw another fuse saying magnetic clutch also ok have heard there is sensors but dont know where or how to check if i plug into a mechanics diagnostic machine is it likely to show up any fault as im low on funds due to cancer and need a cheap fix any help will be great help cheers mark
  2. Re: 2001 s3 air con problem
    If you get someone to turn the AC on and off while you observe and listen to the magnetic clutch,you should hear it clicking,if it doesn't function,there is possibily a fault with the pressure sensor,or the magnetic clutch,a fault code read will show a faulty sensor
  1. Sharan Air Con Problem
    By phall in forum Touran - Sharan - Caravelle
    Last Post: 26-01-2011, 02:12 PM
  2. Question Please diagnose my air con problem!
    By dezzabarks in forum Golf MK5 - 2004 - 2009
    Last Post: 18-11-2009, 07:18 PM
  3. Question Air Con Fault...
    By bora250cr in forum Bora - 1998 - 2005
    Last Post: 21-05-2008, 01:22 PM
  4. Golf TDI Air Con Problem
    By amw5 in forum Chat - Completely Off Topic
    Last Post: 31-12-2006, 05:22 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
