Thread: Radiator leak.... FMIC??
  1. Radiator leak.... FMIC??
    May 2008
    I'm Not sure on this 1 so here's my question : If i were to buy a fmic (Front mounted inter-cooler) Would this replace my radiator??
    Oh my cars a mk4 Gt Tdi 130.
  2. Re: Radiator leak.... FMIC??
    Chester-le-Street, United Kingdom
    no. it only cools the inlet air into the engine cylinders after it has been through the turbo.
    the radiator cools the water which circulates through the block/head.
    i'm not sure if you would need to change the radiator for a unit from a fmic model though,
    someone will be along to help on that issue shortly no doubt,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Radiator leak.... FMIC??
    May 2008
    Ah right, So it would just be an add on to the whole cooling system, which cant be a bad thing!
    Thanks for the reply.
  4. Re: Radiator leak.... FMIC??
    Quote Originally Posted by Matt_130 View Post
    you already have an inter cooler, but it's not front mounted.
    as the air is sucked in by the turbo, it gets compressed,and
    consequently heats up.your intercooler cools it down a bit
    in order to make it more dense, allowing more air to squeeze into
    the cylinders.
    regards,
    stewy.
    4th cog,--two to go
  1. Can I use the garret 1749vb turbo without the FMIC??
    By gbrad2x in forum Golf MK4 - 1999 - 2004
    Last Post: 05-07-2009, 01:19 PM
  2. afn tdi. WHAT FMIC
    By mrjolly in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2008, 10:44 PM
  3. New Project Car
    By andy01745 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2007, 09:20 PM
  4. uprated intercooler
    By NicholasP in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-02-2007, 10:34 AM
  5. POSSIBLE POWER GAINS
    By glen_a4turbo in forum Audi A4 - Archive Topics
    Last Post: 17-08-2006, 08:53 AM
