Thread: Hazard lights - Coupe 1995
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Hazard lights - Coupe 1995
    Feb 2010
    Sudbury UK
    Ok, here's the problem (occassionally):
    I turn on the indicators, left or right, and the hazard lights come on. The garage said it's the hazard switch and when the bloke gave it a tap, it cured it. But, then the problem started again. So, I changed the switch and thought I had fixed it but.............the problem has returned.
    It doesn't happen all the time though !
    Any ideas ??
  2. Re: Hazard lights - Coupe 1995
    Pembrokeshire
    22 Post(s)
    it can only be the hazard switch, or a wiring fault, possibly near the switch. for the hazards to come on with an indicator, both sides must be going live, only possible due to the above.
  3. Re: Hazard lights - Coupe 1995
    Feb 2010
    Sudbury UK
    Well it's doing it less now so I suspect there's an iffy connection with the haz switch. I'll keep an eye on it.
    Now, how do the air vents actually expell air Whatever setting I have, they just don't let any air out (well, very little anyway)......
    Drives me nuts
  4. Re: Hazard lights - Coupe 1995
    Feb 2010
    Sudbury UK
    Sadly I need to revisit this thread as the problem has started again.
    I previously changed the haz switch but to be honest, not much change.
    What happens is that when I select left or right indicator, both start flashing aka hazard lights. This doesn't happen all the time but just lately seems to be more frequent.
    If it's the stalk, is that an easy job to replace and could someone like me (basic skills) be in a position to install a new one (used)......
    Any tips, ideas, notions or solutions are welcome !!
  5. Re: Hazard lights - Coupe 1995
    chairman_mo Guest
    From memory getting the stalk cluster off is fairly straightforward. Temporarily disable airbag (if fitted), remove steering wheel and remove two screws securing upper and lower column shroud. This should expose the stalk assembly and I think they are clamped around the column using a pair of M5 dome deaded allen screws on the underside. Slacken screws, disconnect eletrical connections and slide off column. I think the stalk assembly consists of two cross bolted plates to which the separate switches (wiper, indicator and lights) are mounted on, this is where it gets a bit fiddly unless you have a complete unit to replace rather than just an individual switch. Just make sure you get the correct part and you should be alright.
    Oh and please don't blame me if you knacker it and it doesn't work.
  6. Re: Hazard lights - Coupe 1995
    Feb 2010
    Sudbury UK
    Thanks for the reply.
    Just need to find a replacement stalk now
  7. Re: Hazard lights - Coupe 1995
    chairman_mo Guest
    On ebay there is a guy called audibits2 (used them a couple of times) and they seem good. I will stress I have no connection to them.
  8. Re: Hazard lights - Coupe 1995
    Feb 2010
    Sudbury UK
    I need to revisit this thread as the problem has got worse.
    What happens is that when I select left or right indicator, both start flashing aka hazard lights. This is now happening all the time, i.e. it's hazard lights or nothing.
    I got a replacement stalk assembly fitted and it's made no difference and my mechanic is now baffled.
  9. Re: Hazard lights - Coupe 1995
    Feb 2010
    Sudbury UK
    Mmmmm a week since my last post and no suggestions.
    When I collected the car from the garage on Friday, the indicators were working which is odd because while it was in the garage, they were'nt. 24hrs later though, the indicators don't work again and it's hazards or nothing !!
    Someone pleeeeeeeeease help !!
  10. Re: Hazard lights - Coupe 1995
    Blairgowrie
    have you tried disconnecting the hazard light switch again? see if it returns to normal, at least then you will be safe to drive it. I t is possible to get two faulty switches in a row.
    Pull it out and check the wiring loom plug and wires for seared sleaves in which they may be touching and insulate them. if disturbing the wires makes it more intermittent then it will be a case of trying to separate each of the wires and space them. If it still happens you could unplug hazard switch and rewire direct from the relay in the box.
    essentially it would happen as when your (lets say) nearside indicator illuminates it has live feed........ if there is a wire from the offside indicator circuit touching nearside it will send the power right through and make it look like hazards are on. The only place nearside and off side circuits come close to eachother is at the hazard switch!
    i would try another genuine brand new switch and examine the wiring common to this switch. Hope that helps make the solution a bit more attainable for you as these niggles can be a real pain in the hoop.
  1. DRLs, is this setup possible?
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 08:37 AM
  2. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  3. Rear lights on 1995 ford escort!!
    By marcus in forum Chat - Anything with wheels
    Last Post: 21-09-2007, 02:11 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
