Thread: 1.8t power cuts out at 3000rpm
  1. 1.8t power cuts out at 3000rpm
    Nov 2008
    I am having serious problems! I have an Audi A4 1996 1.8t B5 with a mulit-point injected lpg conversion. It was driving fine last night but this morning is a diferent story- starts fine and drives fine until you get to about 3000 rpm, then it splutters and jolts like there is no fuel getting through or its stalling. It seems to be just as the turbo should kick in, happens in all gears but at higher revs in 1st or 2nd.
    This happens when driving on both lpg and petrol and doesnt matter which gear you are in, however when not in gear it will rev up all the way up and back again completely normally, on either fuel.
    Any guidance would be greatly appreciated.
  2. Re: 1.8t power cuts out at 3000rpm
    Apr 2010
    London
    best bet would be to get a VAG scan done, depending where you are i'm sure someone will offer help for beer tokens possibly.
    that will at least give you a base to post back here with what codes it comes back with
  3. Re: 1.8t power cuts out at 3000rpm
    Nov 2008
    Thanks for coming back to me. I had a good look last night and found a small pipe had come off the Turbo. Dont know what it does and was just pressed onto a nipple. Put it back on, reset the car out of limp mode and it seems to be working fine.
    Thank you again for your post. Hopefully it will be while before I have another porblem!
  4. Re: 1.8t power cuts out at 3000rpm
    Apr 2010
    London
    glad it's running again at least.
    still will be worth getting the scan done, make a post in the VCDS part of the forum with your loacation and one of the excellent people here will be more than willing to help
  1. The efficiency standard – the audi a8 hybrid
    Last Post: 02-03-2010, 07:58 PM
  2. The efficiency standard – the audi a8 hybrid
  3. 02 GT TDI 150pd juddering/loss of power @ 3000rpm
    By ch4chi in forum Golf MK4 - 1999 - 2004
    Last Post: 31-01-2010, 10:33 AM
  4. Power to Weight Ratios
    By Ben in forum Chat - Anything with wheels
    Last Post: 04-09-2007, 02:38 PM
  5. How does the Quattro system work?
