Thread: mk2 gti 16v kr cutting out
  1. mk2 gti 16v kr cutting out
    Nov 2006
    surrey
    hi,
    my 16v gti cuts out when i put the clutch down to come to a stop this doesn't usually start happening until the oil temp reaches 70'c, the revs dip and the oil and battery lights flicker then it dies it always restarts first turn of the key have been told this could be a temp sensor? there are many things i think it could be isv or a gasket or hose perhaps other than this the car drives perfectly thru the whole rev range never misfires so i dont think timing is an issue.
    have also been told that because i dont drive the car much (only 6ooo miles in 2.5 years) it could be something in the throttle body
    Please help any suggestions???
    many thanks
  2. Re: mk2 gti 16v kr cutting out
    Jan 2009
    towcester northants
    check the throttle body to see if clean
    remove idle screw and clean
    when you set up idle disconnect the inline terminal next to coil and set to1050rpm
    this should cure
    if not clean out idle stabilization valve with carb cleaner once cleaned connect and switch ignition on and spray again with it not on car
    if still not right check throttle switches and idle stabilization ecu in centre console
  3. Re: mk2 gti 16v kr cutting out
    Nov 2006
    surrey
    i will try all those suggestions over the weekend and report back tomorrow evening.
    many thanks
  4. Re: mk2 gti 16v kr cutting out
    Nov 2006
    surrey
    update
    cleaned the isv and the idle screw also found a loose injector
    just got back from a test drive and no cutting out was also much more responsive so am happy will clean the throttle body out tomorrow to complete the job
    many thanks for your advice
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  3. Volkswagen presents concepts of the Golf GTI and new Polo
    Last Post: 13-06-2009, 04:20 PM
  4. Volkswagen presents concepts of the Golf GTI and new Polo
    Last Post: 20-05-2009, 09:45 PM
  5. Replies: 0
    Last Post: 28-10-2006, 05:22 PM
