Thread: Fault Codes
  1. Fault Codes
    May 2010
    Leeds, UK
    Hi All
    I had a scan done on my car by a fellow forum member (Imran) and it brought the following codes up.
    Now I know the 2nd one is the MAF, but what does signal too low mean, is it fixable or does it mean a new MAF?
    As for the 1st fault, neither me or Imran know what it means, any ideas guy's?
    Address 01: Engine
    Controller: 8D0 907 558 T
    Component: 1,8L R4/5V MOTR HS D01
    Coding: 04001
    Shop #: WSC 06325
    2 Faults Found:
    17967 - Throttle Valve Control part (J338): Fault in basic settings
    P1559 - 35-00 - -
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-00 - -
    Readiness: N/A
  2. Re: Fault Codes
    Bradford
    According to the vag wiki.
    http://wiki.ross-tech.com/wiki/index...7/P1559/005465
    17967/P1559/005465 - Throttle Body (J338): Fault in Basic Settings
    Possible Symptoms
    • Not known
    Possible Causes
    • Idle Switch Open or Open Circuit
    • Throttle Valve sticks and won't close
    • Speed Impuls from Engine Speed Sensor (G28) recognized
    Possible Solutions
    • Perform Throttle Body Adaptation
  3. Re: Fault Codes
    May 2010
    Leeds, UK
    Thanks Imran
    However, this still means bugger all to me.
    What does "perform throttle body adaptation" mean?
  4. Re: Fault Codes
    Hi Gary,
    First of all, are those the codes that were stored in the car or did you clear the old ones and then check again after running for a few minutes? Sometimes just unplugging a connector and then reconnecting it with the engine running can cause a fault code to be stored.
    Maybe a little experiment will tell you more, like checking the connector on the MAF to se if it is corroded, or reading the codes again with the MAF plug out to see if you get thesame code, then finally take the MAF out to look at - not poke - just look at, and report back or better still upload a photo.
    The more info you supply the more likely someone here can help. OD
  5. Re: Fault Codes
    May 2010
    Leeds, UK
    Hi Old Diver
    These codes were the ones that came up on the 2nd reading. There were a few old ones, but they went are a quick drive.
    The MAF is not a real problem, as the more I drive the car the better fuel consumption I am getting. It's the throttle valve problem that I am stuck on.
  6. Re: Fault Codes
    Use the forum search facility re "throttle body adaptation" - I saw someone mention it a few days ago but I don't remember which thread it was in. OD
  7. Re: Fault Codes
    Bradford
    I did a throttle body adapton on my passat when I bought it. But this was because at idle, the needle kept seeking, the revs were going up and down. Took of the throttle body it was gunked in black crud. Cleaned it and then did a throttle body adaption.
    I suggest you take your throttle body of and have a look at it first. Its the metal bit at the end of the air pipe just left of the water bottle if i remember on your car.
  1. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  2. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
  3. trying to trace this fault with my golf with these codes
    By Fireman2203 in forum VCDS - General Questions
    Last Post: 18-05-2008, 04:26 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. any one had these fault codes??
    By Adamtdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2008, 12:27 AM
