Thread: A8 fingerprint
  1. Exclamation A8 fingerprint
    May 2010
    kent
    Hi i have recently purchased an A8 with fingerprint start, the car dosnt start with my finger so does anyone here know how i can program it so it does?
  2. Re: A8 fingerprint
    May 2007
    knee deep in clunge
    14 Post(s)
    yes reset the profile via mmi menu settings
  3. Exclamation Re: A8 fingerprint
    May 2010
    kent
    excuse me for sounding thick but how excatly do i do that?
  4. Re: A8 fingerprint
    May 2007
    knee deep in clunge
    14 Post(s)
    on the mmi screen
    The fingerprint does not prevent starting as its used for user function memory. I would suggest you have a problem with the start switch
    New user matching is implemented by way of
    the "CAR" menu in the multimedia interface
    (MMI) and can be performed for four users.
    A maximum of 5 fingers can be matched per
    user.
    The MMI provides user prompting for the
    matching process to ensure optimum image
    quality.
    Finger matching is performed by placing it on
    the sensor three times in succession with
    moderate pressure (< 12 N). The first time, the
    finger should be placed in normal centre
    position, then approx. 2 mm to the left and
    finally 2 mm to the right.
    Further prints may be necessary depending
    on image quality. If this is the case, the user
    will be informed by way of an appropriate
    prompt in the MMI.
    Three finger images must be read in and
    stored before a person can be identified.
    At least one finger must be matched.
    To rule out identification problems, it is
    however appropriate to match two or several
    fingers.
  5. Exclamation Re: A8 fingerprint
    May 2010
    kent
    thank you!
  6. Re: A8 fingerprint
    May 2007
    knee deep in clunge
    14 Post(s)
    you have two options
    owners handbook paper back
    owners handbook cd rom load into the 6 disc changer and select on the mmi
  7. Exclamation Re: A8 fingerprint
    May 2010
    kent
    the cd can be bought on ebay cant it? i just printed off what you told me about the programming so will probably be in my garage till late tonight! also while im speaking to an expert my doors dont open when i get to the car in the morning eben though it has the keyless entry.....any ideas?
  1. The efficiency standard – the audi a8 hybrid
    Last Post: 02-03-2010, 07:58 PM
  2. The efficiency standard – the audi a8 hybrid
  3. All-new audi a8 travels light to miami debut
    Last Post: 16-12-2009, 06:00 PM
  4. All-new audi a8 travels light to miami debut
    Last Post: 02-12-2009, 08:58 PM
  5. Please Help Join me in saying THANK YOU - with beer!
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-11-2009, 10:14 PM
