Thread: no power and very loud engine - 2.5 tdi
Results 1 to 10 of 18
  1. no power and very loud engine - 2.5 tdi
    Jan 2008
    hi guys,
    did not want to hijack the other thread regarding the loud engine..
    Recently my car has developed zero power and a very loud engine, probably louder than a tractor (i'm not even joking)... the power has totally gone even though it wasn't as quick as other 2.5 tdi's, but not its very slow cant even get up a hill.
    Any ideas?
    Been to a few mechanics, one is saying the turbo has gone again (there is no smoke by the way),
    second one is saying your engine is shot,
    third one which is my main mechanic, who did all the work recently when my turbo messed up (££££), said he thinks the timing is out and needs checking, so he is going to strip it down on monday (timing belt was changed 30k ago)
    Are any of these correct??? i am hoping it is the timing
    thanks
  2. Re: no power and very loud engine - 2.5 tdi
    Aug 2007
    Hook Hampshire
    21 Post(s)
    If it is not the camshafts and associated bits breaking up as in the recent post, it could be the camshaft tensioner bolt that has sheared. this happened on my car and luckily there was no cobsequestial damage.
    A broken bolt will ofcourse cause the fuel injection timming to be out.
    Audi A7 3.0TDi 2011 180k miles, engine code CLAB 204bhp 2WD
  3. Re: no power and very loud engine - 2.5 tdi
    135 Post(s)
    2036 Post(s)
    Pull the left cam cover (it is slightly easier to remove than the right) and check the lobes for wear and thrown cam levers.
  4. Re: no power and very loud engine - 2.5 tdi
    Jan 2008
    it's in the garage since monday, so will hopefully find out the damage today...
    this cars costing me a fortune lately!!
  5. Re: no power and very loud engine - 2.5 tdi
    Jan 2008
    mechanic said the engines gone, but i dont understand as it still drives... I am sure its the timing, does anyone know if anyone has vag.com in the sheffield area?
    thanks
  6. Re: no power and very loud engine - 2.5 tdi
    Aug 2007
    Hook Hampshire
    21 Post(s)
    [QUOTE=audi bwoy;513430]mechanic said the engines gone, but i dont understand as it still drives... I am sure its the timing, does anyone know if anyone has vag.com in the sheffield area?
    If a mechanic says the engine is gone without any explanation, then you should change your mechanic. What he appears to be saying is that he has not a clue. You say he has stripped it down in our prevous posts. Ask what the faults are and post these here. Withot the stripdown info, it is difficult to make an assessment
    Try C&R enterprises in Nottingham. Vagcom is unlikely to tell you anything useful with thye symptoms yo have. Remove head covers and timing covers. The visual inspection will probably reveal the cause.
  7. Re: no power and very loud engine - 2.5 tdi
    Jan 2008
    cheers shabazmo, i need to find out exactly what is wrong with it, your right, but he is very hard to talk too, hes always too busy.
    If the timing is out can it cause these symptoms?
  8. Re: no power and very loud engine - 2.5 tdi
    135 Post(s)
    2036 Post(s)
    The valve and/or pump timing being out can make a diesel sound terrible.
  9. Re: no power and very loud engine - 2.5 tdi
    Jan 2008
    thanks crasher, i hope it is the timing, just need to find someone local to me with vag.com now.. btw i am in sheffield.
  10. Re: no power and very loud engine - 2.5 tdi
    Oct 2009
    Doncaster
    try this guy http://www.germancarspecialistdoncaster.com/ give him a call because i had my car serviced from a different garage and oil was leaking everywhere so i took it to him and he charged me about £50 and he put a new filter in and cleaned all the engine and under body plate
