Thread: Golf mk5 gt tdi stuck in gear
Results 1 to 8 of 8
  1. Golf mk5 gt tdi stuck in gear
    Sep 2008
    Just bought a gt tdi 69000 miles 04 plate
    On throttle off you can see the clutch pedal move up
    and on throttle moves down slightly
    WHen you put it into reverse or first gear to park, it is occasionaly difficult to get it out of gear.
    If you are still rolling you can do it no problem , but at stand still can be difficult.
    I was thinking worn engine mount, and the engine is moving ?
    what do you guys think.
    It has had a clutch and flywheel replaced recently.
  2. Re: Golf mk5 gt tdi stuck in gear
    May 2010
    Devon England
    do you know if the slave cylinder was replaced at the same time? also do you know if it was an after market clutch and flywheel that was fitted?
  3. Re: Golf mk5 gt tdi stuck in gear
    Sep 2008
    No the slave was not replaced , would this make a difference ?
  4. Re: Golf mk5 gt tdi stuck in gear
    May 2010
    Devon England
    Quote Originally Posted by big_pete View Post
    it could do, does the clutch pedal feel normal or is there more free play than there should be? i always change the slave as a matter of course cos the box is out, yes it may add a few pound to the bill but it saves having to take the box out again if it leaks or gives problems
  5. Re: Golf mk5 gt tdi stuck in gear
    Sep 2008
    chester
    17 Post(s)
    Take that back to whoever did the clutch,clutch pedal should not be moving on its own!,the selector cables might need adjusting,that could explain the stiff gears.
  6. Re: Golf mk5 gt tdi stuck in gear
    Sep 2008
    Checked the engine mounts today and they look good, I was thinking maybe selector cables, but that doesnt explain the clutch pedal movement.
  7. Re: Golf mk5 gt tdi stuck in gear
    Sep 2008
    chester
    17 Post(s)
    Look on U tube theres a short video on selector cables resetting procedure.
  8. Re: Golf mk5 gt tdi stuck in gear
    Sep 2008
    cool thanks mate
  1. MK5 Golf Tdi 140/170 worthy successor to the MK4 Tdi 150?
    By iworld in forum Golf MK5 - 2004 - 2009
    Last Post: 02-06-2010, 11:26 PM
  2. Vw Golf mk5 gt tdi TURBO OVER BOOST
    By anthugs77 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-05-2010, 11:33 PM
  3. Please Help Golf GT TDI 130 little issue
    By benaknoun in forum Golf MK4 - 1999 - 2004
    Last Post: 07-04-2010, 07:57 PM
  4. Golf TDi GT140 vs Leon TDI FR
    By UltraViolet in forum Chat - Anything with wheels
    Last Post: 08-06-2009, 01:23 PM
