Thread: Help!!! No reverse lights
  1. Help!!! No reverse lights
    Apr 2009
    Malvern,Worcestershire
    hi everyone my first post on here but i have been a member for a while now! in desparate need of some help i am pulling my hair out!!! i have an a4 avant with mysterious issue simply its the reverse lights not working but i just cant find the fault the fuse is fine also the bulbs are ok i think the switch is working on the gearbox as when i put a meater on the fuse connections and select reverse it goes from nothing to around 7 volts? but when i put the meater on the cluster connections it remains at 0!! any help would be very much apreciated as my mot is on the horison!!
  2. Re: Help!!! No reverse lights
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    A continuity test from the switch to the lamp units would tell you if the power is getting lost between the two
    Stuart
  3. Re: Help!!! No reverse lights
    Jul 2008
    stoke on trent
    cant help with problem but reverse lights are not tested or required for an mot
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  4. Re: Help!!! No reverse lights
    Apr 2009
    Thanks I will give it a try and see what happens!!! And out of interest is the switch the one above the near side drive shaft? ;] kev
  5. Re: Help!!! No reverse lights
    Apr 2009
    Thanks I did not know that but for my own satisfaction I need to find the problem I hate to be beaten!!!;]
  6. Re: Help!!! No reverse lights
    Feb 2014
    Glasgow
    Sorry for the thread revival but should my 2003 A4 Avant have one or two reverse lights?
  1. DRLs, is this setup possible?
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 08:37 AM
  2. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  3. Dash problem? No reverse lights?
    By shane14 in forum Touran - Sharan - Caravelle
    Last Post: 09-08-2009, 04:36 PM
  4. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
