Thread: Juddering/Rev Needle shaking
  1. Juddering/Rev Needle shaking
    Just noticed the other day when i started my car (51 1.8t)it was juddering alot and the rev needle was shaking when i was parked up in neutral.
    It feels like its about to cut out but if i rev it it stays alive...however thought id see what'd happen if i didnt rev it and eventually it cut out.
    The follwing day was doing the same thing and engine managment light came on.
    Anyone got any ideas/experiences with this? Really hope its not expensve whatever it is.
  2. Re: Juddering/Rev Needle shaking
    Jul 2010
    Belfast
    Quote Originally Posted by faisalgti View Post
    I also have this. Only had it cut out once and it was very hard to get started again.
    When idle, it will sit around 800 rpm and then shake about 100rpm on either side and occassional judders. Could be normal but I suspect it isnt?
  3. Re: Juddering/Rev Needle shaking
    Aug 2010
    malvern
    Sounds like its MAF related....
  4. Re: Juddering/Rev Needle shaking
    Had the problem sorted.
    It was a split in the airpipe they replaced that and its as good as new now
  1. Speedo needle vibrates when ignition turned on
    By Bill Badger in forum Golf MK4 - 1999 - 2004
    Last Post: 26-07-2010, 10:44 AM
  2. please help with needle illumination
    By A6TYY in forum VCDS - General Questions
    Last Post: 12-10-2009, 08:59 PM
  3. Question Gauge needle sweep
    By Soot1e in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-09-2009, 10:04 AM
  4. 2.5TDi Needle Lift Sensor
    By SimonBbk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-01-2009, 01:23 AM
  5. Needle Lift Sensor
    By Deks82 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-03-2008, 09:24 AM
