Thread: DTC codes on 2002 1.4 Polo
Results 1 to 10 of 11
  1. DTC codes on 2002 1.4 Polo
    Apr 2010
    England
    The engine check light, and EPC light come on, eventually clear, then reappear.
    Today I connected a DTC code reader and found the following:
    17750 P1342 Ignition Control Power Output Stage 1 Short to B+
    18043 P1635 Databus Powertrain missing message from air condition control
    Generall, the engine runs OK, but I did hear a slight pinking sometimes on acceleration. The plugs were recently replaced (DTC's preceeded that), and the coil packs were changed not so long ago.
    Can anyone interpret the codes, i.e what is likely the problem(s)?
  2. Re: DTC codes on 2002 1.4 Polo
    134 Post(s)
    2018 Post(s)
    What is the engine code?
  3. Re: DTC codes on 2002 1.4 Polo
    Apr 2010
    England
    Its a BBY engine (auto)
  4. Re: DTC codes on 2002 1.4 Polo
    134 Post(s)
    2018 Post(s)
    What code reader are you using? According to my info a 2002 9N1 Polo BBY cannot generate code 17750, that only applies to cars with a single four output coil pack, not cars with four separate coil packs.
    Does your car have Climatic or Climatronic A/C?
  5. Re: DTC codes on 2002 1.4 Polo
    Apr 2010
    England
    It has Climatronic.
    The code reader is a CAN VW/AUDI U281 Memoscan unit I got off eBay.
  6. Re: DTC codes on 2002 1.4 Polo
    134 Post(s)
    2018 Post(s)
    I don’t think it is interpreting the code correctly, you car does have four individual coil packs so it can’t generate
    17750 Ignition outlet 1 Short circuit to positive
    According to the VAG system Guided Fault Finding, 17750 (hex code 4556) does not apply to that car.
  7. Re: DTC codes on 2002 1.4 Polo
    Apr 2010
    England
    I reset the ECU by disconnecting the battery, thinking this would also reset and relearn the fuel map.
    Anyway,what I've noticed is when the codes are cleared, I can drive 100 miles on the motorway and not throw any codes. When I come off the motorway and decelerate/slow down at a junction, it throws the code. Similarly, on a short journey, I set off (with no codes showing), and before long, often after braking/decelerating the EPC and Engine Check Light appear.
    I connected the DTC reader, and saw the following:
    16407 - Bank 2: Camshaft B (Exhaust): Position Actuator Malfunction
    I'm new to VW, so I have no idea about this. But I'm wondering could it be related to earthing? Or the firmware in the ECU? Or could it be an actuator, or something influencing the actuator signal (though this is a 4 cyl engine with 1 bank only)?
    EDIT The DTC code structure implies its related to computer and output signals:
    Px6xx computer and output signals
  8. Re: 16407 P0023 DTC codes on 2002 1.4 Polo
    Apr 2010
    England
    Found something potentially useful on Google - it was in Dutch, so I used Goole language tools to translate:
    16407 P0023 Bank 2: B camshaft (exhaust) Position Actuator Malfunction
    Additional information on the error codes. Intermittent
    Possible causes:
    * Probably a software issue
    * Wiring and / or connections
    * Camshaft position control mechanism
    * Motor control module
    Possible solutions:
    * Check with the dealer or a software update
    * Check / repair wiring and / or connections
    * Check / repair the camshaft position control mechanism
    CHEC * / replace engine control module
    Certainly, its an intermittent (but often occuring fault)
    Is the camshaft position control a likely candidate? Is that an easy swap?
    I've also heard that cambelt tensioners can wear prematurely - could that be a possibility?
  9. Re: DTC codes 16407 and P0023 on 2002 1.4 BBY Polo
    Apr 2010
    England
    More info trawled from Google:
    Synopsis TPI 2001317 / 7
    Polo, Lupo: check engine light bulb and recorded error 17550 or 16407 Polo, Lupo: check engine light bulb and recorded error 17550 or 16407
    Publication date: 05.08.2008 Date: 05.08.2008
    Description of fault: Description of fault:
    Steady light check engine, memory control unit engine for one of the following errors: Steady light check engine, memory control unit engine for one of the following errors:
    17550 P1142 Accounting load, the output of the lower limit 17550 P1142 Accounting load, the output of the lower boundary
    16407 P0023 Row 2, variable valve timing, exhaust valves, the disruption of 16407 P0023 Row 2, variable valve timing, exhaust valves, malfunctioning
    Decision: Decision:
    In the case of a complaint to upgrade software engine control unit. In the case of a complaint to upgrade software engine control unit. If the engine control unit is installed on new urgency, for further troubleshooting should take advantage wingman troubleshooting. If the engine control unit is installed on new urgency, for further troubleshooting should take advantage wingman troubleshooting.
    The search order is given in the section of the driven troubleshooting. The search order is given in the section of the driven troubleshooting. Service companies in Germany, a position connected to a network tester can update the software online. Service companies in Germany, a position connected to a network tester can update the software online. To solve these problems, all users tester VAS 5051 with brand CD V06.44.00 received from the firm Bertelsmann CD Adaptation ECU versions 001-2003, article 001.5001.22.00. </span>To solve these problems, all users tester VAS 5051 with brand CD V06.44.00 received from the firm Bertelsmann CD Adaptation ECU versions 001-2003, article 001.5001.22.00.
    Are these 'Row 2/bank B' signals completely spurious, e.g. due to a software error, and relatively harmless? Or is something else going on here?
    </span>
  10. Re: DTC codes on 2002 1.4 Polo
    Apr 2010
    England
    Crasher,
    WRT your comments that the fault code does not apply to this model, I did find some postings on another site (I think it was relating to a Ibiza) where similar codes were shown - also not related to the model in question.
    17750, or P1142, it says, could be related to an air leak (cannot hear anything), or MAF. What do you think? One Jetta user said he changed the MAF, but the problem only went away after he changed the fuel pump (coincidence?).
    WRT 16407, I don't lnow
    There are plenty of posts on a Website called My VW Lemon with odd problems like this...
    I'm thinking to clean the throttle body, check my earth, and other connections, and take fault finding from there.
  1. Faulty heater matrix 2002 1.4 TDI polo?
    By sonny85 in forum Polo - Derby - Lupo - Fox
    Last Post: 30-03-2010, 04:04 PM
  2. Please Help 2002 Polo 1.4 Petrol Intermittent Non Starting
    By Rollo Tomasi in forum Polo - Derby - Lupo - Fox
    Last Post: 21-12-2009, 07:53 PM
  3. Replies: 0
    Last Post: 10-08-2009, 09:47 PM
  4. Volkswagen announces prices for new polo as car goes on sale
  5. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
