Thread: Has my B6 passat been clocked
Results 1 to 9 of 9
  1. Has my B6 passat been clocked
    May 2010
    merseyside uk
    Having looked at the instrument section using vcds my vehicle mileage reads 40936 miles but the ecu says it is 55908, that is a massive difference and I wondered how easy it is to clock a b6 passat.....vagcom expects a 5% difference but this is 15000 miles.
    any info would be appreciated.
    I am new to vag com but reading until my eyes bleed.
  2. Re: Has my B6 passat been clocked
    notts
    seems a bit out but i wouldnt have thought someone would have gone to the trouble of clocking it for 15k miles?
  3. Re: Has my B6 passat been clocked
    Pembrokeshire
    22 Post(s)
    as above really. why not try checking it again in 100 miles and see if both have gone up by the same amount.
  4. Re: Has my B6 passat been clocked
    135 Post(s)
    2036 Post(s)
    The EDC calculation is never that much out, usually a few hundred miles at most. 15K is about 1 years average mileage and can make a fair difference to the value, would be easy to cover up and not raise any suspicions in most cases.
  5. Re: Has my B6 passat been clocked
    May 2010
    merseyside uk
    thanks for the replies, I have been told by the local dealership that a 15000 mile descrepancy is not possible within the realms of normality so I guess that it has probably been altered or had a secondhand ecu fitted at some point.
    As Crasher has pointed out 15000miles is easy to hide and all of the service schedule books etc are in good order with what look like lowish mileage between services, so perhaps it had a really high mileage year and the previous owner or garage wound it back for warranty or value purposes.
  6. Re: Has my B6 passat been clocked
    Mansfield, UK
    Secondhand ECUs are hard to code in and usually becomes a dealer job, so the likelyhood of a secondhand ECU being fitted is quite low to be honest.
    I would suggest that your car has had the mileage altered at some point in it's life.
  7. Re: Has my B6 passat been clocked
    May 2010
    merseyside uk
    Thanks for that Mr shark..it looks extremely likely that scullduggery is the answer LOL I am probably best just living with it, I suppose 15k is more palatable than say 40-50 or 60k.
    paul
  8. Re: Has my B6 passat been clocked
    Oct 2009
    Staines, UK
    I can't get the EDC calculation to work at all on my b6.
    Any ideas why this would be? Engine is BKP
  9. Re: Has my B6 passat been clocked
    135 Post(s)
    2036 Post(s)
    It does seem to be erratic; I have found very few cars that it works on but then again I don’t try it very often, just if I have a few minutes to spare and I remember to try it.
  1. Canbus / towbar wiring Passat B6 estate
    By pp241 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 17-07-2016, 08:22 PM
  2. Question B6 Passat 2006 torque wrench settings
    By freebird69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-08-2009, 09:12 PM
  3. Hi I'm a newbie...some questions about vw passat b6
    By wanzalizan in forum New Member Introductions
    Last Post: 05-04-2009, 12:36 AM
  4. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
